Since I have upgraded to a 2.2 Snapshot - Build 1072 I am experiencing a bit of intermittent flakyness with the HUE EMULATION binding and Alexa.
When I try and ask ALEXA to turn something on or off, she tells me that the item is not responding. When this occurs, I see the following in the OH log.
This situation will clear after a period of time and then ALEXA is able to successfully process the request.
Any suggestions are greatly appreciated.
Squid
2017-11-06 20:31:14.142 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /api/IpcI4oOGWNiM5yrMmomJswLE3ctYhogoZRxPBnrs/lights/Ceiling_Fan/state
java.lang.NumberFormatException: For input string: "Ceiling_Fan"
at java.lang.NumberFormatException.forInputString(Unknown Source) ~[?:?]
at java.lang.Integer.parseInt(Unknown Source) [?:?]
at java.lang.Integer.<init>(Unknown Source) [?:?]
at org.openhab.io.hueemulation.internal.HueEmulationServlet.apiState(HueEmulationServlet.java:323) [226:org.openhab.io.hueemulation:2.2.0.201710292329]
at org.openhab.io.hueemulation.internal.HueEmulationServlet.service(HueEmulationServlet.java:281) [226:org.openhab.io.hueemulation:2.2.0.201710292329]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) [30:javax.servlet-api:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:845) [85:org.eclipse.jetty.servlet:9.3.14.v20161028]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [85:org.eclipse.jetty.servlet:9.3.14.v20161028]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [171:org.ops4j.pax.web.pax-web-jetty:6.0.6]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.3.14.v20161028]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [171:org.ops4j.pax.web.pax-web-jetty:6.0.6]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [85:org.eclipse.jetty.servlet:9.3.14.v20161028]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [171:org.ops4j.pax.web.pax-web-jetty:6.0.6]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:320) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [84:org.eclipse.jetty.server:9.3.14.v20161028]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273) [76:org.eclipse.jetty.io:9.3.14.v20161028]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95) [76:org.eclipse.jetty.io:9.3.14.v20161028]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [76:org.eclipse.jetty.io:9.3.14.v20161028]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [87:org.eclipse.jetty.util:9.3.14.v20161028]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [87:org.eclipse.jetty.util:9.3.14.v20161028]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [87:org.eclipse.jetty.util:9.3.14.v20161028]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [87:org.eclipse.jetty.util:9.3.14.v20161028]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [87:org.eclipse.jetty.util:9.3.14.v20161028]
at java.lang.Thread.run(Unknown Source) [?:?]
2017-11-06 20:31:14.143 [WARN ] [org.eclipse.jetty.server.HttpChannel] - //10.5.1.50:8080/api/IpcI4oOGWNiM5yrMmomJswLE3ctYhogoZRxPBnrs/lights/Ceiling_Fan/state
2017-11-06 20:31:14.233 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /api/IpcI4oOGWNiM5yrMmomJswLE3ctYhogoZRxPBnrs/lights/Ceiling_Fan/state
2017-11-06 20:31:14.234 [WARN ] [org.eclipse.jetty.server.HttpChannel] - //10.5.1.50:8080/api/IpcI4oOGWNiM5yrMmomJswLE3ctYhogoZRxPBnrs/lights/Ceiling_Fan/state
