I noticed that I’m only getting an updated illuminance reading when the Hue Sensor is detecting motion.
I set up my Hue bridge through the Paper UI (ie I have no declaration for the Hue bridge in my items or things files). I thought it may be related so I tried to declare the Hue bridge in a .things file, but it raises error as the bridge is already known.
In PaperUI, the Hue Bridge has the default sensor polling interval (500ms).
Any idea on what I should do to get timely illuminance readings?
@sihui Yes, that the behavior I’m seeing too. What I would like is to get an update value more often or at least when a significant change is detected. Seems like a pretty basic need for home automation rules.
This is what I am seeing in the logs for a Hue outdoor I connected via zigbee2mqtt:
2020-01-05 19:09:02.176 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18492 to 18427
2020-01-05 19:24:38.751 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 18360
2020-01-05 19:25:17.163 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 18427
2020-01-05 19:27:36.437 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 19869
2020-01-05 19:27:41.438 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 19869 to 18360
2020-01-05 19:28:24.471 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 18293
2020-01-05 19:28:29.512 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18293 to 18360
2020-01-05 19:28:34.529 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 18427
2020-01-05 19:28:36.101 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 18360
2020-01-05 19:29:48.253 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 18427
2020-01-05 19:30:03.247 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 18360
2020-01-05 19:31:46.628 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 18427
2020-01-05 19:31:56.656 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 18360
2020-01-05 19:32:08.251 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 19822
2020-01-05 19:32:13.220 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 19822 to 18360
2020-01-05 19:32:18.161 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 18427
2020-01-05 19:34:03.931 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 18360
2020-01-05 19:35:53.933 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 19822
2020-01-05 19:35:58.970 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 19822 to 18427
2020-01-05 19:38:46.496 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 18360
2020-01-05 19:38:51.525 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 18427
2020-01-05 19:39:43.149 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 19822
2020-01-05 19:39:48.147 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 19822 to 18360
2020-01-05 19:39:53.151 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 18427
2020-01-05 19:40:21.310 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 19822
2020-01-05 19:40:26.340 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 19822 to 18360
2020-01-05 19:42:01.840 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 18427
2020-01-05 19:42:11.839 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 18360
2020-01-05 19:43:05.649 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 19822
2020-01-05 19:43:10.649 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 19822 to 18427
2020-01-05 19:43:15.680 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 18360
2020-01-05 19:44:21.830 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 19869
2020-01-05 19:44:26.900 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 19869 to 18427
2020-01-05 19:44:32.291 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 18360
2020-01-05 19:45:18.706 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 19822
2020-01-05 19:45:23.777 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 19822 to 18360
2020-01-05 19:45:28.710 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 18427
2020-01-05 19:46:54.804 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 19822
2020-01-05 19:46:59.840 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 19822 to 18427
2020-01-05 19:48:50.749 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 18360
2020-01-05 19:49:00.763 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 18427
2020-01-05 19:49:44.428 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 19869
2020-01-05 19:49:49.460 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 19869 to 18427
2020-01-05 19:50:43.490 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 18360
2020-01-05 19:52:40.268 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 18427
2020-01-05 19:53:45.396 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 19822
2020-01-05 19:53:50.401 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 19822 to 18293
2020-01-05 19:53:55.397 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18293 to 18360
2020-01-05 19:54:04.269 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 18427
2020-01-05 19:55:51.743 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 19822
2020-01-05 19:55:56.766 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 19822 to 18360
2020-01-05 19:56:29.184 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18360 to 18427
2020-01-05 19:57:45.279 [vent.ItemStateChangedEvent] - Hue_Out_2_Lux changed from 18427 to 18293
Interesting… I would like to keep things IP / HTTP based on my side so I’ll be looking at the HTTP binding to query the Hue bridge. Still, I suspect I should not need do do that and missing something with the out-of-the-box behavior of the Hue binding.
