Dear community,
I programmed my Homematic motion sensor to switch on a Hue Lightstrip. Strip is switched on and (after a timer) also switched off. But somehow my code is not changing the color… I’ve already checked the community and tried different ways for the sendCommand (predefined variable like below, item.sendCommand (“123,234,123”), sendCommand (item,123,234,123), but without success… The color stays always the same. Any hint or idea?
Item swBewegungGangMotion changed to ON
HueLightstripPlus1Color.sendCommand(ColourMorning)
HueLightstripPlus1ColorTemperature.sendCommand(20)
HueLightstripPlus1.sendCommand(ON)
createTimer(now.plusSeconds(10))
HueLightstripPlus1.sendCommand(OFF)
No, I haven’t managed yet to create/check the log files, since it’s running on a Synology Diskstation, where this seems more complicated. And I don’t know how I can write something into the Visual Studio Code output field (e.g. by some command like an ordinary “printf”)…
If a Hue Light strip works like my other Hue color bulbs, setting color temperature wipes out any color setting. In other words, your rule sets the color of the light strip, then it sets the temperature, probably changing your previously set color. Also, you might have to turn it on before setting the color. On my Hue color bulbs can have temperature set when they are off, then when turned on will be that temperature, not sure color works the same.
thank you for your answer. I detected my mistake! Defining the colors, I did not define them as HSB but as RGB. So switching on/off I took over some code I encountered in the forum as follows
var DecimalType hue = new DecimalType(240) // 0-360; 0=red, 120=green, 240=blue, 360=red(again)
var PercentType sat = new PercentType(50) // 0-100
var PercentType bright = new PercentType(80) // 0-100
var HSBType light = new HSBType(hue,sat,bright)
HueLightstripPlus1Color.sendCommand(light)
createTimer(now.plusSeconds(5)) [|
Although there is now an “ambiguous feature call” by the line “HueLightstripPlus1Color.sendCommand(light)”, it does work correctly.
