I am trying to get two Philips Hue SML002 ZigBee outdoor motion sensors to work. I can pair them to show “ONLINE” and get channels like
- Switch
- Temperature
- Occupancy
- Illuminance
But somehow I don’t get any events when there is motion on the Occupancy channel. Also, what is the switch for? When I try setting it to ON I get “OnOff converter is not linked to a server and cannot accept commands” in the debug logs.
This is with OH 2.5.0.M3 and 2.5.0.201909222250 ZigBee stack.
Other interesting thing is that the zigbee_neighbors and zigbee_routes is an empty array in properties. I don’t see anything happening in the debug logs, no updates at all. When triggering ZigBee search in PaperUI I can see that there potentially is connectivity, so its probably not a range issue:
2019-09-30 12:48:45.810 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=32589/0,
destinationAddress=0/0, profile=0000, cluster=0013, addressMode=null, radius=0, apsSecurity=false, apsCounter=--, payl
oad=6F 4D 7F 1F 48 45 06 01 88 17 00 80]
2019-09-30 12:48:45.811 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: DeviceAnnounce [32589/0 -> 0/0, cluste
r=0013, TID=--, nwkAddrOfInterest=32589, ieeeAddr=001788010645481F, capability=128]
2019-09-30 12:48:45.811 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: DeviceAnnounce [3258
9/0 -> 0/0, cluster=0013, TID=--, nwkAddrOfInterest=32589, ieeeAddr=001788010645481F, capability=128]
-> 31885/1, cluster=0000, TID=--, identifiers=[5]]]
2019-09-30 12:48:45.810 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis Data:RX:7F4D,0000,00,00,0013,0C:o
M^?^_HE^F^A<U+0088>^W^@<U+0080>,-59,FE
2019-09-30 12:48:45.810 [DEBUG] [gesis.internal.TelegesisFrameHandler] - RX Telegesis: TelegesisReceiveMessageEvent [ie
eeAddress=null, networkAddress=32589, profileId=0, destinationEp=0, sourceEp=0, clusterId=19, messageData=6F 4D 7F 1F 4
8 45 06 01 88 17 00 80, rssi=-89, lqi=254]
9/0 -> 0/0, cluster=0013, TID=--, nwkAddrOfInterest=32589, ieeeAddr=001788010645481F, capability=128] ZigBeeTransaction
[queueTime=22135, state=TRANSMITTED, sendCnt=1, command=ManagementLqiRequest [0/0 -> 55414/0, cluster=0031, TID=37, st
artIndex=0]]
[queueTime=24073, state=TRANSMITTED, sendCnt=2, command=ReadAttributesCommand [Basic: 0/0 -> 31885/1, cluster=0000, TI
D=26, identifiers=[5, 4, 3, 2, 6, 0, 1]]]
2019-09-30 12:48:45.812 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: DeviceAnnounce [3258
artIndex=0]]
[queueTime=716594, state=TRANSMITTED, sendCnt=2, command=ReadAttributesCommand [Occupancy Sensing: 0/0 -> 748/2, clust
er=0406, TID=AA, identifiers=[0]]]
2019-09-30 12:48:45.812 [DEBUG] [p.discovery.ZigBeeDiscoveryExtension] - DISCOVERY Extension: Mesh related command rece
ived. Triggering mesh update.
2019-09-30 12:48:45.812 [DEBUG] [p.discovery.ZigBeeDiscoveryExtension] - DISCOVERY Extension: Start mesh update task with interval of 86400 seconds
2019-09-30 12:48:45.814 [DEBUG] [pp.discovery.ZigBeeNetworkDiscoverer] - 001788010645481F: Device announce received. NWK=32589
2019-09-30 12:48:45.814 [DEBUG] [pp.discovery.ZigBeeNetworkDiscoverer] - 001788010645481F: NWK Discovery add node 32589
2019-09-30 12:48:45.815 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - 001788010645481F: Node state updated from UNKNOWN to ONLINE
2019-09-30 12:48:45.815 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - 001788010645481F: Updating node NWK=32589
2019-09-30 12:48:45.816 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - 001788010645481F: Node 32589 update
2019-09-30 12:48:45.816 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - 001788010645481F: Node 32589 is not updated
Any ideas?
