in the meanwhile some huge changed happened to the hue-binding (how things are handled did change i think).
After i did re-configure the channel of the bulbs (in items file), everything worked like aspected. But my hue power socket / dimmer are not visible as thing any longer.
2016-07-16 23:06:23.336 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate command 'ON' for item 'Licht_Schubladen' to handler for channel 'hue::00178823af43:3:brightness', because no thing with the UID 'hue::00178823af43:3' could be found.
2016-07-16 23:06:23.344 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item 'Licht_Schubladen' to handler for channel 'hue::00178823af43:3:brightness', because no thing with the UID 'hue::00178823af43:3' could be found.
2016-07-16 23:06:23.507 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate command '100' for item 'Licht_Stehlampe' to handler for channel 'hue::00178823af43:2:brightness', because no thing with the UID 'hue::00178823af43:2' could be found.
2016-07-16 23:06:23.515 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '100' for item 'Licht_Stehlampe' to handler for channel 'hue::00178823af43:2:brightness', because no thing with the UID 'hue::00178823af43:2' could be found.
2016-07-16 23:06:33.133 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate command 'ON' for item 'Licht_Kueche_Spuele' to handler for channel 'hue::00178823af43:15:brightness', because no thing with the UID 'hue::00178823af43:15' could be found.
2016-07-16 23:06:33.142 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'ON' for item 'Licht_Kueche_Spuele' to handler for channel 'hue::00178823af43:15:brightness', because no thing with the UID 'hue::00178823af43:15' could be found.
2016-07-16 23:07:33.879 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate command 'OFF' for item 'Licht_Kueche_Spuele' to handler for channel 'hue::00178823af43:15:brightness', because no thing with the UID 'hue::00178823af43:15' could be found.
2016-07-16 23:07:33.880 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'Licht_Kueche_Spuele' to handler for channel 'hue::00178823af43:15:brightness', because no thing with the UID 'hue::00178823af43:15' could be found.
I can’t find them at the paper ui. Are they not longer supported by the binding?
