So strange.
I have a fresh OH2 install and the Hue binding added. Nothing else.
This is all i see in my logs.
2016-07-15 13:23:58.008 [ItemStateChangedEvent ] - hue__00178824e7e9_11_color changed from 90,95,100 to 189,94,100
2016-07-15 13:24:48.022 [ItemStateChangedEvent ] - hue__00178824e7e9_11_color changed from 189,94,100 to 68,88,100
2016-07-15 13:26:02.508 [ItemCommandEvent ] - Item 'hue__00178824e7e9_11_color' received command OFF
2016-07-15 13:26:02.508 [ItemStateChangedEvent ] - hue__00178824e7e9_11_color changed from 68,88,100 to 68,88,0
2016-07-15 13:26:04.438 [ItemCommandEvent ] - Item 'hue__00178824e7e9_11_color' received command ON
2016-07-15 13:26:04.438 [ItemStateChangedEvent ] - hue__00178824e7e9_11_color changed from 68,88,0 to 68,88,100
In the classic ui, For the bulb all I see is 2 ‘rows’ in the browser, the Color and Color Temperature.
And within the paper ui, if you visit controls there is a ‘Dimmer’ slider for the color bulbs. But setting that to 0 does not turn the bulb off?
All pretty strange. I am in the USA and I had read in the past that I though the zigbee was different in the USA vs Europe? Not that I think that should be making a difference here.
But not once in the log do I see an INCREASE or DECREASE command.
EDIT.
I did get the device to INCREASE and DECREASE. I’m so used to sliders, I didnt’ realize in the classic UI that you need to press and hold an up or down arrow.
So dimming the bulb to 0 seems to work. But the Dimmer ‘slider’ in the Paper UI Controls does not dim a bulb. I’m not sure if that is bug or something else?
