Is there a way for OH to poll or know the state of a hue when switched on manually (with a regular wall switch)?
All you should have to do is make sure you have a refresh rate set for the hue binding in openhab.cfg.
Thanks, that’s what I thought. However, I am only reading the last known state by OH. If I change it via OH and inquire it’s state it gives the right value. If I change the Hue’s state with a third party app or via a switch it keeps reporting the old value. My openhab.cfg has a refresh of 10000 ms.
I’m running 1.8.1
I’ve got the same setup and mine does pickup the actual state of the bulb, regardless of how it was changed. Are you sure the line isn’t commented out?
Restarting OH fixed it.
