I have a flush mounted zigbee Busch Jaeger Switch which works perfectly fine in the hue app.
Using the switch item and the switch channel I am even able to control it with openhab:
Switch hueBjKitchenroom_Switch_Color "Kitchen switch" [ "Lighting" ] { channel="hue:0000:0017884e4cbd:4:switch" }
But the problem is that it wont get updated when I change the state from outside of openhab and this happens quite often as I use the switch itself. The strange thing is that it updates in the hue app. So the hue app shows the correct state all the time (regardless where I changed the state). Therefor there might be a bug in the binding as the switch and the hue app seem to work perfectly.
I am using OH 2.1 stable.
