I read many articles around the way to use the offset and it is working but when I review events.log and openhab.log I don’t understand what is happening.
This is my item.
Number:Temperature HueBadkamerTemperatuurTemperature "Hue badkamer temp [%.1f °C]" <temperature> (EV_Badkamer) ["Measurement","Temperature"] {channel="hue:0302:1d920141a4:11:temperature" [profile="offset", offset="-1.9 °C"] }
And this is what I see in the logfiles
2022-11-24 08:39:34.539 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'HueBadkamerTemperatuurTemperature' changed from 19.58 °C to 19.07 °C
2022-11-24 08:39:34.543 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'HueBadkamerTemperatuurLastUpdated' changed from 2022-11-24T08:34:35.000+0100 to 2022-11-24T08:39:35.000+0100
2022-11-24 08:39:34.529 [WARN ] [nternal.profiles.SystemOffsetProfile] - Received a QuantityType state '22.07 °C' with unit, but the offset is defined as a plain number without unit (-3), please consider adding a unit to the profile offset.
2022-11-24 08:39:34.532 [WARN ] [nternal.profiles.SystemOffsetProfile] - Received a QuantityType state '22.07 °C' with unit, but the offset is defined as a plain number without unit (-3), please consider adding a unit to the profile offset.
2022-11-24 08:39:34.539 [WARN ] [nternal.profiles.SystemOffsetProfile] - Received a QuantityType state '22.07 °C' with unit, but the offset is defined as a plain number without unit (-3), please consider adding a unit to the profile offset.
Questions:
- Why is it reporting “consider adding a unit” . I did this.
- What means “(-3)” the offset is -1.9
- Why do I see 3 lines in the logging?
What do I wrong?
