Hue with Lightify Plug
I am using Philips Hue Bridge with a Osram Lightify Plug. I run openHAB 2.0.0-1 (Release Build) with OpenHABian. I use only the Paper UI. When I scan the Hue bridge all things are found (lamps, plugs). I have also a device from Dresden Elektronik (FLS-PP lp) which can integrate without problem.
The Lightify Plug is problem:
  • I can create a thing for it, then when I try to create an item, I get an error. I found this message in the log:
    [WARN ] [thome.io.rest.core.item.ItemResource] - Received HTTP PUT request at ‘items/Gees_Gast_Nachttischlampe_Dose’ with an invalid item type ‘SwitchItem’.
    When I create a new item there is only “SwitchItem” available as type.
  • The thing I have created for the plug shows “online” after creation. After some time (I haven´t measured the time) it goes to offline for no reason. I can then delete the item and recreate it and it will be online again. I have not found another way to get it online again.
exactly the same Problem here… any solution?
No. I think it is a bug since there is not other option in the dialog. I wonder if this is the right place for bug reports or if I should post it here: https://github.com/openhab/openhab-distro
now, it works.
i created a items file in “/etc/openhab2/items” (osramplug.items) which contains the follow String:
Switch Steckdose1 “Lampe Sideboard” [ “Switchable” ] {channel=“hue:0010:0017884875e3:4:switch”}
thats it
Great! That works. :slight_smile:
…but still configuration with the Paper UI still gives an error. :frowning:
Hello Gerd_Sender,
Did you already try it in Habmin?? Because there are also problems with change settings in zwave devices.
@Thetmar: I don´t know what you mean with HabMin. I use the Paper UI. Osram also used ZigBee (here via Philips Hue).
@billygeen: My plugs are mostly shown as “offline”. Because Hue shows them as offline Openhab does not update the status and HomeKit does not control them at all. :pensive:
Do have the same behaviour?
I found my problem: not Hue is loosing contact, HomeKit looses the contact to OpenHab. After a few minutes it is shown as “offline”.
Thanks, it works. Testet a lot of old suggestions regarding the same problem!
