Since yesterday all “of a sudden” I get an **Huebridge exception **from the binding every 10 seconds.
The only thing that “happened” was that I had installed the Rest UI (I am not sure whether it was directly related) but even after uninstalling the exception still appears.
Note
- All Hue devices do work fine
- I did try to press the pairing button on the bridge as mentioned in some github issues but that did not fix the problem.
- I restarted openhab but the problem stays.
- I am on openhab 2.4. The hue binding is 2.4.0.SNAPSHOT
Any idea what to do next as it clutters my logs very much (and I am not sure if it has any other side effect)
TIA
Stefan
2018-08-15 07:45:12.133 [ERROR] [binding.hue.handler.HueBridgeHandler] - An unexpected error occurred: com.google.gson.annotations.SerializedName.alternate()[Ljava/lang/String;
java.lang.NoSuchMethodError: com.google.gson.annotations.SerializedName.alternate()[Ljava/lang/String;
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory.getFieldNames(ReflectiveTypeAdapterFactory.java:79) ~[16:com.google.gson:2.7.0]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory.getBoundFields(ReflectiveTypeAdapterFactory.java:159) ~[16:com.google.gson:2.7.0]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory.create(ReflectiveTypeAdapterFactory.java:100) ~[16:com.google.gson:2.7.0]
at com.google.gson.Gson.getAdapter(Gson.java:423) ~[16:com.google.gson:2.7.0]
at com.google.gson.internal.bind.MapTypeAdapterFactory.create(MapTypeAdapterFactory.java:126) ~[16:com.google.gson:2.7.0]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory.createBoundField(ReflectiveTypeAdapterFactory.java:115) ~[16:com.google.gson:2.7.0]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory.getBoundFields(ReflectiveTypeAdapterFactory.java:164) ~[16:com.google.gson:2.7.0]
at com.google.gson.Gson.fromJson(Gson.java:886) ~[16:com.google.gson:2.7.0]
at com.google.gson.Gson.fromJson(Gson.java:852) ~[16:com.google.gson:2.7.0]
at com.google.gson.Gson.fromJson(Gson.java:801) ~[16:com.google.gson:2.7.0]
at com.google.gson.Gson.fromJson(Gson.java:773) ~[16:com.google.gson:2.7.0]
at org.eclipse.smarthome.binding.hue.internal.HueBridge.getFullConfig(HueBridge.java:842) ~[203:org.eclipse.smarthome.binding.hue:0.10.0.201806141343]
at org.eclipse.smarthome.binding.hue.handler.HueBridgeHandler$1.run(HueBridgeHandler.java:107) [203:org.eclipse.smarthome.binding.hue:0.10.0.201806141343]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
