Hi guys,
Since a few days I wonder why my auto discovery service doesn´t work anymore.
I have running an openhabian unstable snapshot release
openHAB 2.5.0~S1487-1 (Build #1487)
on Raspberry PI 3
I mainly work with deConz Raspbee module to manage all my lights for month without any trouble. By the way, I´m happy about the Dresden Electronic Binding.
But recently my inbox has stopped working regardless of types I´m searching for (Hue, Network Binding and so on)
What I have done:
- many restarts
- update deconz
- update java zulu
- clean cache, tmp and try out openhab-cli clean
My installed bindings:
These are my debug messages:
Summary
2019-01-04 23:30:04.059 [ERROR] [ue.internal.handler.HueBridgeHandler] - An exception occurred while calling the BridgeHeartbeatListener
at org.eclipse.smarthome.binding.hue.internal.discovery.HueLightDiscoveryService.onLightAddedInternal(HueLightDiscoveryService.java:147) ~[212:org.eclipse.smarthome.binding.hue:0.11.0.201901030053]
at org.eclipse.smarthome.binding.hue.internal.discovery.HueLightDiscoveryService.onLightAdded(HueLightDiscoveryService.java:140) ~[212:org.eclipse.smarthome.binding.hue:0.11.0.201901030053]
at org.eclipse.smarthome.binding.hue.internal.handler.HueBridgeHandler.notifyLightStatusListeners(HueBridgeHandler.java:645) [212:org.eclipse.smarthome.binding.hue:0.11.0.201901030053]
at org.eclipse.smarthome.binding.hue.internal.handler.HueBridgeHandler.access$7(HueBridgeHandler.java:634) [212:org.eclipse.smarthome.binding.hue:0.11.0.201901030053]
at org.eclipse.smarthome.binding.hue.internal.handler.HueBridgeHandler$2.doConnectedRun(HueBridgeHandler.java:243) [212:org.eclipse.smarthome.binding.hue:0.11.0.201901030053]
at org.eclipse.smarthome.binding.hue.internal.handler.HueBridgeHandler$PollingRunnable.run(HueBridgeHandler.java:101) [212:org.eclipse.smarthome.binding.hue:0.11.0.201901030053]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
and
Summary
2019-01-04 23:37:17.505 [ERROR] [nternal.DiscoveryServiceRegistryImpl] - Cannot trigger scan for thing types ‘[hue:0010, hue:0107, hue:0106, hue:0820, hue:0830, hue:0302, hue:0200, hue:0100, hue:0210, hue:0220, hue:0000, hue:0110]’ on ‘HueLightDiscoveryService’!
at org.eclipse.smarthome.binding.hue.internal.discovery.HueLightDiscoveryService.onLightAddedInternal(HueLightDiscoveryService.java:147) ~[?:?]
at org.eclipse.smarthome.binding.hue.internal.discovery.HueLightDiscoveryService.startScan(HueLightDiscoveryService.java:122) ~[?:?]
at org.eclipse.smarthome.config.discovery.AbstractDiscoveryService.startScan(AbstractDiscoveryService.java:211) ~[98:org.eclipse.smarthome.config.discovery:0.11.0.201901030053]
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:381) [98:org.eclipse.smarthome.config.discovery:0.11.0.201901030053]
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScans(DiscoveryServiceRegistryImpl.java:357) [98:org.eclipse.smarthome.config.discovery:0.11.0.201901030053]
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:215) [98:org.eclipse.smarthome.config.discovery:0.11.0.201901030053]
at org.eclipse.smarthome.io.rest.core.internal.discovery.DiscoveryResource.scan(DiscoveryResource.java:97) [120:org.eclipse.smarthome.io.rest.core:0.11.0.201901030053]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [20:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) [85:org.eclipse.jetty.servlet:9.4.12.v20180830]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) [85:org.eclipse.jetty.servlet:9.4.12.v20180830]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [186:org.ops4j.pax.web.pax-web-jetty:7.2.5]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.4.12.v20180830]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1340) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [186:org.ops4j.pax.web.pax-web-jetty:7.2.5]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) [85:org.eclipse.jetty.servlet:9.4.12.v20180830]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1242) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [186:org.ops4j.pax.web.pax-web-jetty:7.2.5]
at org.eclipse.jetty.server.Server.handle(Server.java:503) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:364) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.12.v20180830]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305) [75:org.eclipse.jetty.io:9.4.12.v20180830]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [75:org.eclipse.jetty.io:9.4.12.v20180830]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:765) [87:org.eclipse.jetty.util:9.4.12.v20180830]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:683) [87:org.eclipse.jetty.util:9.4.12.v20180830]
Any idea ?
