- Platform information:
- Hardware: RPI3 - ARMv7 Processor rev 4 (v7l)/976 MB/29777
- OS: raspbian / VERSION=“10 (buster)”
- Java Runtime Environment: openjdk version “1.8.0_222”
- openHAB version: openhab-distro : 2.5.5
- Issue of the topic:
Hello, I’m trying to expose two zwave switches, currently connected to a zwave Aeotec usb driver, to be controled by one Amazon Echo device. I also have a Hue bridge controlling other hue lights that are also working as expected either via voice commands from Amazon Echo or from Openhab.
I installed the binding Hue Emulation binding by following all the instructions from https://www.openhab.org/addons/integrations/hueemulation/ and after installation I can even see new “CLIP*” sensors from my existing lights reported in the inbox of the paper UI.
I’m also able to perform the troubleshooting section by testing the status http://openhab:8080/api/status where I can see the two lights I added to my items and/or checking description and query the two lights.
This an extract of the output for the status command:
Self test
To access any links you need be in pairing mode!
Pairing mode: On (V2) Enable | Enable with bridge V1 emulation
2 published lights (see http://192.168.1.51:8080/api/testuser/lights)
70 published sensors (see http://192.168.1.51:8080/api/testuser/sensors)UPnP discovery test
success
serial no name 5F461H160922 Roku 2 20100621 [TV] Living room 0017882d83e2 Philips hue (192.168.1.52)
But I think I’m missing something because the following messages are reported in the event and info logs approximately every 10 seconds.
2020-05-26 19:23:12.669 [WARN ] [ue.internal.handler.HueBridgeHandler] - An unexpected error occurred: null
at org.openhab.binding.hue.internal.handler.HueBridgeHandler$2.doConnectedRun(HueBridgeHandler.java:272) ~[bundleFile:?]
at org.openhab.binding.hue.internal.handler.HueBridgeHandler$PollingRunnable.run(HueBridgeHandler.java:121) [bundleFile:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_222]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
2020-05-26 19:23:12.715 [hingStatusInfoChangedEvent] - ‘hue:bridge:CEEA5244AB8B’ changed from ONLINE to OFFLINE: Hue bridge connection lost.
2020-05-26 19:23:12.726 [hingStatusInfoChangedEvent] - ‘hue:0840:CEEA5244AB8B:28’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-05-26 19:23:12.737 [hingStatusInfoChangedEvent] - ‘hue:0840:CEEA5244AB8B:54’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-05-26 19:23:12.790 [hingStatusInfoChangedEvent] - ‘hue:bridge:CEEA5244AB8B’ changed from OFFLINE: Hue bridge connection lost. to ONLINE
2020-05-26 19:23:12.809 [hingStatusInfoChangedEvent] - ‘hue:0840:CEEA5244AB8B:28’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-05-26 19:23:12.829 [hingStatusInfoChangedEvent] - ‘hue:0840:CEEA5244AB8B:54’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-05-26 19:23:13.159 [hingStatusInfoChangedEvent] - ‘hue:0100:1:BSMT_BULB_03’ changed from OFFLINE: Hue bridge reports light as not reachable. to ONLINE
Items:
Switch FF_SW_FR_1 “Family Room []” [“Lighting”] { channel=“zwave:device:d898ae3f:node3:switch_dimmer” }
Switch FF_SW_FY_1 “Foyer []” [“Lighting”] { channel=“zwave:device:d898ae3f:node5:switch_binary” }
