Hi
I’m a beginner and try to setup hue emulation.
I got only a hue bulb to test with. Therefor also no user name from a Hue bridge.
Setup the binding and try to configure the hue emulation.
The emulation stays offline with the “Authentication failed. Remove user name from configuration to generate a new one”.
I tried with just a name and removed it afterwards. But it still ask to remove the user name. What can I do?
Does the Hue emulation gets its own ip address beside the ip of then openhab?
Thanks for any help
Vik
AddOn:
When I disable/enable the Thing the log says “Failed to create new user on the hue bridge”
(CONFIGURATION_ERROR). I’m doing all configuration in Papaer UI. Is there an other place?
Reading and come up with idea: For Hue lights a real HueBridge is necessary. Or in other words it will not work without a physical HueBridge. Correct?
