Platform information:
Hardware: Raspberry Pi 4
OS: Raspbian Buster
Java Runtime Environment: 1.8.0_222
openHAB version: Openhabian 2.5
i have a warning from hueemulation in my log though there ist no hueemulation bridge in the inbox nor in the things section:
[WARN ] [ueemulation.internal.upnp.UpnpServer] - Could not send UPNP response: Cannot assign requested address (sendto failed)
I use a ConbeeII USB Gateway and the deonz binding.
Everything works fine and all needed things are found and online.
The warning comes up every 2 minutes. What i did so far:
Configuration-> Services->IO->HUE Emulation:
- Pairing enabled
- Unknown user-keys enabled
- optional discovery ip set to raspberry/deconz ip
Then the hueemulation bridge appears in the inbox, but offline.
Reboot.
The Warning appears again.
Edited the hueemulation bridge-> ip4 adress of rasperry/deconz and Port:80
Hueemulation Bridge is now online.
Reboot
Nearly 100 new useless “Things” in my Inbox, something like: Flur_oben CLIP Generic Flag SensorFlur_oben, look like my items…?
Hueemulation Bridge has changed the Port to 8081, the port of my openhab installation.
The Warning appears furthermore every 2 minutes…
Deleted Hueemulation Bridge->Reboot-> Inbox empty, but warning is still there.
Has anyone an idea?
