Hi all,
Thought I’d share a quick rule I wrote up to get my humidifier settings on my CT80 to adjust based on the outside temperature. Didn’t find anything to this effect already posted.
rule "Set Humidity"
Item Temperature_F changed
var int Temp = (Temperature_F.state as DecimalType).intValue
logInfo("thermostat", "Temp_outside = " + Temp)
if(Temp < 40){
var int Humid = (Temp*0.5+25).intValue
logInfo("thermostat", "Humidity set point " + Humid)
sendCommand(RT_TStat_THumidity,Humid)
sendCommand(RTTStatPMAMessage, "Out:" + Temp.toString)
Pretty straight forward, every time the temperature binding changes the outside temperature it recalculates the indoor target humidity. I turned mine down a bit from the “recommended” humidity I found online, to keep condensation from forming on my windows when it dips below freezing, by swapping the 25 for a 20 (5% lower than recommended). It might need some other adjustments based on your particular climate.
Also tossed a line on there at the end to dump the outside temperature to the CT80s display (not sure if the ct50 and ct100 have that ability)
I’ve only had a few days below 40 since I put it in place, but the few nights we’ve dropped to cooler temperatures we’ve had an easier time breathing in our house over night, time will tell how the condensation does this winter compared to years past.
