My sensor is showing the number F0AF182700000000 on page 3.
It is a DS2438 sensor + HIH403 humidity sensor. I bought it here: https://www.tm3d.de/shop/kategorien/module
Paper UI identifies this sensor just as Multisensor ( ms-tx ) without humidity signal.
What should I do, to get also the humidity signal? Change F0 by 19?
Thank you for your support.
Thank you for the hint. I did it with owhttp and it is working now. Changed F0AF182700000000 to 19AF182700000000 on page.3. Would be helpful, if this is mentioned in the documentation.
