Hi OpenHabians,
I am new here + just trying to get started with OH and HUSBZB-1 and I cannot get online the coordinator for zigbee, please help
The ZWAVE binding works fine.
Thanks in advance.
Platform information:
Hardware: Mac Mini/OSX 10.14.15
OS: what OS is used and which version
Java Runtime Environment: Zulu8
openHAB version:2.4
Issue of the topic: HUSBZB-1 Zigbee Coordinator showing Offline- Communication error
Openhab debug log below.
2020-02-17 22:51:20.317 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Processing zigbee_port -> /dev/tty.GoControl_zigbee
2020-02-17 22:51:20.317 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_initialise as no change
2020-02-17 22:51:20.317 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_channel as no change
2020-02-17 22:51:20.317 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_concentrator as no change
2020-02-17 22:51:20.317 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_trustcentremode as no change
2020-02-17 22:51:20.317 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_extendedpanid as no change
2020-02-17 22:51:20.318 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_flowcontrol as no change
2020-02-17 22:51:20.318 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_baud as no change
2020-02-17 22:51:20.318 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_panid as no change
2020-02-17 22:51:20.318 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_powermode as no change
2020-02-17 22:51:20.318 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_txpower as no change
2020-02-17 22:51:20.318 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_installcode as no change
2020-02-17 22:51:20.319 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_networksize as no change
2020-02-17 22:51:20.319 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_linkkey as no change
2020-02-17 22:51:20.319 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_childtimeout as no change
2020-02-17 22:51:20.319 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_networkkey as no change
2020-02-17 22:51:20.319 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_meshupdateperiod as no change
2020-02-17 22:51:20.351 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=SHUTDOWN
2020-02-17 22:51:20.383 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6F000B3D491A: ZigBee saving network state complete.
2020-02-17 22:51:20.387 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network [zigbee:coordinator_ember:84b571a6] closed.
2020-02-17 22:51:20.388 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Initializing ZigBee Ember serial bridge handler.
2020-02-17 22:51:20.389 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initializing ZigBee network [zigbee:coordinator_ember:84b571a6].
2020-02-17 22:51:20.389 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Channel 11
2020-02-17 22:51:20.389 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - PANID 33716
2020-02-17 22:51:20.389 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - EPANID 2F880359823F92BF
2020-02-17 22:51:20.390 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network Key 423A0A3AFAACD256A15D721268D1066E
2020-02-17 22:51:20.390 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link Key 5A6967426565416C6C69616E63653039
2020-02-17 22:51:20.390 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_initialise found, initializeNetwork=false
2020-02-17 22:51:20.390 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network Key String 423A0A3AFAACD256A15D721268D1066E
2020-02-17 22:51:20.391 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network key final array 423A0A3AFAACD256A15D721268D1066E
2020-02-17 22:51:20.392 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link Key String 5A6967426565416C6C69616E63653039
2020-02-17 22:51:20.392 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link key final array 5A6967426565416C6C69616E63653039
2020-02-17 22:51:20.393 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - ZigBee Ember Coordinator opening Port:'/dev/tty.GoControl_zigbee' PAN:83b4, EPAN:2F880359823F92BF, Channel:11
2020-02-17 22:51:20.393 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Ember end device poll timout set to (169 * 2^9) = 86528 seconds
2020-02-17 22:51:20.394 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
2020-02-17 22:51:21.398 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2020-02-17 22:51:21.398 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2020-02-17 22:51:21.399 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
2020-02-17 22:51:21.404 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6F000B3D491A: ZigBee reading network state complete.
2020-02-17 22:51:21.405 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Connecting to serial port [/dev/tty.GoControl_zigbee] at 57600 baud, flow control FLOWCONTROL_OUT_XONOFF.
2020-02-17 22:51:21.427 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port [/dev/tty.GoControl_zigbee] is initialized.
2020-02-17 22:51:25.543 [ERROR] [tsystems.zigbee.ZigBeeNetworkManager] - 000D6F000B3D491A: Adding local node to network: NWK unknown
2020-02-17 22:51:25.544 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Mesh Update Period 86400
2020-02-17 22:51:25.580 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee Initialise: Previous device configuration was: channel=CHANNEL_00, PanID=65535, EPanId=0000000000000000
2020-02-17 22:51:25.580 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_trustcentremode=TC_JOIN_SECURE
2020-02-17 22:51:25.859 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=SHUTDOWN
2020-02-17 22:51:25.861 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6F000B3D491A: ZigBee saving network state complete.
2020-02-17 22:51:25.995 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port '/dev/tty.GoControl_zigbee' closed.
2020-02-17 22:51:25.996 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network [zigbee:coordinator_ember:84b571a6] closed.
at com.zsmartsystems.zigbee.dongle.ember.EmberNcp.getNetworkState(EmberNcp.java:261) ~[?:?]
at com.zsmartsystems.zigbee.dongle.ember.ZigBeeDongleEzsp.waitNetworkStartup(ZigBeeDongleEzsp.java:539) ~[?:?]
at com.zsmartsystems.zigbee.dongle.ember.ZigBeeDongleEzsp.startup(ZigBeeDongleEzsp.java:495) ~[?:?]
at com.zsmartsystems.zigbee.ZigBeeNetworkManager.startup(ZigBeeNetworkManager.java:638) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.initialiseZigBee(ZigBeeCoordinatorHandler.java:500) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler.lambda$2(ZigBeeCoordinatorHandler.java:535) ~[?:?]
2020-02-17 22:51:26.882 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Initializing ZigBee Ember serial bridge handler.
2020-02-17 22:51:26.882 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initializing ZigBee network [zigbee:coordinator_ember:84b571a6].
2020-02-17 22:51:26.882 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Channel 11
2020-02-17 22:51:26.882 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - PANID 33716
2020-02-17 22:51:26.882 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - EPANID 2F880359823F92BF
2020-02-17 22:51:26.882 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network Key 423A0A3AFAACD256A15D721268D1066E
2020-02-17 22:51:26.883 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link Key 5A6967426565416C6C69616E63653039
2020-02-17 22:51:26.883 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_initialise found, initializeNetwork=false
2020-02-17 22:51:26.883 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network Key String 423A0A3AFAACD256A15D721268D1066E
2020-02-17 22:51:26.883 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network key final array 423A0A3AFAACD256A15D721268D1066E
2020-02-17 22:51:26.883 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link Key String 5A6967426565416C6C69616E63653039
2020-02-17 22:51:26.883 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link key final array 5A6967426565416C6C69616E63653039
2020-02-17 22:51:26.883 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - ZigBee Ember Coordinator opening Port:'/dev/tty.GoControl_zigbee' PAN:83b4, EPAN:2F880359823F92BF, Channel:11
2020-02-17 22:51:26.883 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Ember end device poll timout set to (169 * 2^9) = 86528 seconds
2020-02-17 22:51:26.884 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
2020-02-17 22:51:27.888 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2020-02-17 22:51:27.889 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2020-02-17 22:51:27.890 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
2020-02-17 22:51:27.891 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6F000B3D491A: ZigBee reading network state complete.
2020-02-17 22:51:27.892 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Connecting to serial port [/dev/tty.GoControl_zigbee] at 57600 baud, flow control FLOWCONTROL_OUT_XONOFF.
2020-02-17 22:51:27.906 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port [/dev/tty.GoControl_zigbee] is initialized.
2020-02-17 22:51:32.076 [ERROR] [tsystems.zigbee.ZigBeeNetworkManager] - 000D6F000B3D491A: Adding local node to network: NWK unknown
2020-02-17 22:51:32.076 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Mesh Update Period 86400
2020-02-17 22:51:32.079 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee Initialise: Previous device configuration was: channel=CHANNEL_00, PanID=65535, EPanId=0000000000000000
2020-02-17 22:51:32.079 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_trustcentremode=TC_JOIN_SECURE
2020-02-17 22:51:37.470 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=OFFLINE
2020-02-17 22:51:38.475 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=SHUTDOWN
2020-02-17 22:51:38.480 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6F000B3D491A: ZigBee saving network state complete.
2020-02-17 22:51:38.638 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port '/dev/tty.GoControl_zigbee' closed.
2020-02-17 22:51:38.639 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2020-02-17 22:51:38.640 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
2020-02-17 22:51:38.643 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6F000B3D491A: ZigBee reading network state complete.
2020-02-17 22:51:38.643 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Connecting to serial port [/dev/tty.GoControl_zigbee] at 57600 baud, flow control FLOWCONTROL_OUT_XONOFF.
2020-02-17 22:51:38.661 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port [/dev/tty.GoControl_zigbee] is initialized.
2020-02-17 22:51:42.862 [ERROR] [tsystems.zigbee.ZigBeeNetworkManager] - 000D6F000B3D491A: Adding local node to network: NWK unknown
2020-02-17 22:51:42.863 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Mesh Update Period 86400
2020-02-17 22:51:42.865 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee Initialise: Previous device configuration was: channel=CHANNEL_00, PanID=65535, EPanId=0000000000000000
2020-02-17 22:51:42.865 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_trustcentremode=TC_JOIN_SECURE
The binding documentation doesn’t say to set the debug to ALL and this is not valid (hence the error). As I said earlier, you need to configure the logging as per the binding documentation. That states the following -:
Looks like there are various types of logging - having lots to learn
So here is my openhab log following the log commands provided.
This is the only error that sticks out:
Any suggestions are appreciated.
THX
2020-02-18 14:30:51.629 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=SHUTDOWN
2020-02-18 14:30:51.634 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6F000B3D491A: ZigBee saving network state complete.
2020-02-18 14:30:51.765 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port '/dev/tty.GoControl_zigbee' closed.
2020-02-18 14:30:51.766 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network [zigbee:coordinator_ember:84b571a6] closed.
2020-02-18 14:30:53.626 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Initializing ZigBee Ember serial bridge handler.
2020-02-18 14:30:53.626 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initializing ZigBee network [zigbee:coordinator_ember:84b571a6].
2020-02-18 14:30:53.626 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Channel 11
2020-02-18 14:30:53.626 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - PANID 33716
2020-02-18 14:30:53.627 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - EPANID 2F880359823F92BF
2020-02-18 14:30:53.627 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network Key 423A0A3AFAACD256A15D721268D1066E
2020-02-18 14:30:53.627 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link Key 5A6967426565416C6C69616E63653039
2020-02-18 14:30:53.627 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_initialise found, initializeNetwork=false
2020-02-18 14:30:53.627 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network Key String 423A0A3AFAACD256A15D721268D1066E
2020-02-18 14:30:53.627 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network key final array 423A0A3AFAACD256A15D721268D1066E
2020-02-18 14:30:53.627 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link Key String 5A6967426565416C6C69616E63653039
2020-02-18 14:30:53.628 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link key final array 5A6967426565416C6C69616E63653039
2020-02-18 14:30:53.628 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - ZigBee Ember Coordinator opening Port:'/dev/tty.GoControl_zigbee' PAN:83b4, EPAN:2F880359823F92BF, Channel:11
2020-02-18 14:30:53.628 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Ember end device poll timout set to (169 * 2^9) = 86528 seconds
2020-02-18 14:30:53.628 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
2020-02-18 14:30:54.631 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2020-02-18 14:30:54.631 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2020-02-18 14:30:54.632 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
2020-02-18 14:30:54.636 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6F000B3D491A: ZigBee reading network state complete.
2020-02-18 14:30:54.637 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Connecting to serial port [/dev/tty.GoControl_zigbee] at 57600 baud, flow control FLOWCONTROL_OUT_XONOFF.
2020-02-18 14:30:54.655 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port [/dev/tty.GoControl_zigbee] is initialized.
2020-02-18 14:30:58.802 [ERROR] [tsystems.zigbee.ZigBeeNetworkManager] - 000D6F000B3D491A: Adding local node to network: NWK unknown
2020-02-18 14:30:58.802 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Mesh Update Period 86400
2020-02-18 14:30:58.805 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee Initialise: Previous device configuration was: channel=CHANNEL_00, PanID=65535, EPanId=0000000000000000
2020-02-18 14:30:58.805 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_trustcentremode=TC_JOIN_SECURE
2020-02-18 14:31:04.181 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=OFFLINE
2020-02-18 14:31:05.187 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=SHUTDOWN
2020-02-18 14:31:05.190 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6F000B3D491A: ZigBee saving network state complete.
2020-02-18 14:31:05.344 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port '/dev/tty.GoControl_zigbee' closed.
2020-02-18 14:31:05.345 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2020-02-18 14:31:05.346 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
2020-02-18 14:31:05.348 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6F000B3D491A: ZigBee reading network state complete.
2020-02-18 14:31:05.348 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Connecting to serial port [/dev/tty.GoControl_zigbee] at 57600 baud, flow control FLOWCONTROL_OUT_XONOFF.
2020-02-18 14:31:05.363 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port [/dev/tty.GoControl_zigbee] is initialized.
2020-02-18 14:31:09.505 [ERROR] [tsystems.zigbee.ZigBeeNetworkManager] - 000D6F000B3D491A: Adding local node to network: NWK unknown
2020-02-18 14:31:09.506 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Mesh Update Period 86400
2020-02-18 14:31:09.508 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee Initialise: Previous device configuration was: channel=CHANNEL_00, PanID=65535, EPanId=0000000000000000
2020-02-18 14:31:09.508 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_trustcentremode=TC_JOIN_SECURE
2020-02-18 14:33:23.368 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration received (Coordinator).
2020-02-18 14:33:23.369 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_port as no change
2020-02-18 14:33:23.369 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_initialise as no change
2020-02-18 14:33:23.370 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_channel as no change
2020-02-18 14:33:23.370 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_concentrator as no change
2020-02-18 14:33:23.370 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_trustcentremode as no change
2020-02-18 14:33:23.370 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_extendedpanid as no change
2020-02-18 14:33:23.370 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_flowcontrol as no change
2020-02-18 14:33:23.370 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_baud as no change
2020-02-18 14:33:23.371 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_panid as no change
2020-02-18 14:33:23.371 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_powermode as no change
2020-02-18 14:33:23.371 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_txpower as no change
2020-02-18 14:33:23.371 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_installcode as no change
2020-02-18 14:33:23.371 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_networksize as no change
2020-02-18 14:33:23.372 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_linkkey as no change
2020-02-18 14:33:23.372 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_childtimeout as no change
2020-02-18 14:33:23.372 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_networkkey as no change
2020-02-18 14:33:23.372 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration update: Ignored zigbee_meshupdateperiod as no change
2020-02-18 14:33:27.820 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=SHUTDOWN
2020-02-18 14:33:27.824 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6F000B3D491A: ZigBee saving network state complete.
2020-02-18 14:33:27.970 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port '/dev/tty.GoControl_zigbee' closed.
2020-02-18 14:33:27.971 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network [zigbee:coordinator_ember:84b571a6] closed.
2020-02-18 14:33:29.711 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Initializing ZigBee Ember serial bridge handler.
2020-02-18 14:33:29.711 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initializing ZigBee network [zigbee:coordinator_ember:84b571a6].
2020-02-18 14:33:29.711 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Channel 11
2020-02-18 14:33:29.711 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - PANID 33716
2020-02-18 14:33:29.711 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - EPANID 2F880359823F92BF
2020-02-18 14:33:29.711 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network Key 423A0A3AFAACD256A15D721268D1066E
2020-02-18 14:33:29.715 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link Key 5A6967426565416C6C69616E63653039
2020-02-18 14:33:29.715 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_initialise found, initializeNetwork=false
2020-02-18 14:33:29.716 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network Key String 423A0A3AFAACD256A15D721268D1066E
2020-02-18 14:33:29.716 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network key final array 423A0A3AFAACD256A15D721268D1066E
2020-02-18 14:33:29.716 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link Key String 5A6967426565416C6C69616E63653039
2020-02-18 14:33:29.716 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link key final array 5A6967426565416C6C69616E63653039
2020-02-18 14:33:29.716 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - ZigBee Ember Coordinator opening Port:'/dev/tty.GoControl_zigbee' PAN:83b4, EPAN:2F880359823F92BF, Channel:11
2020-02-18 14:33:29.716 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Ember end device poll timout set to (169 * 2^9) = 86528 seconds
2020-02-18 14:33:29.716 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
2020-02-18 14:33:30.718 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2020-02-18 14:33:30.719 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2020-02-18 14:33:30.719 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
2020-02-18 14:33:30.723 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6F000B3D491A: ZigBee reading network state complete.
2020-02-18 14:33:30.723 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Connecting to serial port [/dev/tty.GoControl_zigbee] at 57600 baud, flow control FLOWCONTROL_OUT_XONOFF.
2020-02-18 14:33:30.738 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port [/dev/tty.GoControl_zigbee] is initialized.
2020-02-18 14:33:34.879 [ERROR] [tsystems.zigbee.ZigBeeNetworkManager] - 000D6F000B3D491A: Adding local node to network: NWK unknown
2020-02-18 14:33:34.880 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Mesh Update Period 86400
2020-02-18 14:33:34.882 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee Initialise: Previous device configuration was: channel=CHANNEL_00, PanID=65535, EPanId=0000000000000000
2020-02-18 14:33:34.882 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_trustcentremode=TC_JOIN_SECURE
2020-02-18 14:33:40.276 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=OFFLINE
2020-02-18 14:33:41.282 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=SHUTDOWN
2020-02-18 14:33:41.285 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6F000B3D491A: ZigBee saving network state complete.
2020-02-18 14:33:41.354 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port '/dev/tty.GoControl_zigbee' closed.
2020-02-18 14:33:41.354 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2020-02-18 14:33:41.355 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
2020-02-18 14:33:41.359 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 000D6F000B3D491A: ZigBee reading network state complete.
2020-02-18 14:33:41.360 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Connecting to serial port [/dev/tty.GoControl_zigbee] at 57600 baud, flow control FLOWCONTROL_OUT_XONOFF.
2020-02-18 14:33:41.381 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port [/dev/tty.GoControl_zigbee] is initialized.
2020-02-18 14:33:45.618 [ERROR] [tsystems.zigbee.ZigBeeNetworkManager] - 000D6F000B3D491A: Adding local node to network: NWK unknown
2020-02-18 14:33:45.618 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Mesh Update Period 86400
2020-02-18 14:33:45.621 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee Initialise: Previous device configuration was: channel=CHANNEL_00, PanID=65535, EPanId=0000000000000000
2020-02-18 14:33:45.621 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_trustcentremode=TC_JOIN_SECURE
I believe the problem is now resolved, by luck/ accident.
I did enable Reset controller option and set the channel to Auto - now the Coordinator came online.
