I don’t know if it’s the correct one or not, it’s from the guide I followed that I posted in my second post. I’m starting to think it might be a driver problem. Here’s what it looks like in Device Manager.
COM3 is the one that was HubZ Z-Wave Com Port, and COM4 is the one that was HubZ ZigBee Com Port. After manually installing the driver on each (the guide I followed had me select the same driver for each, and that is suspect in my mind) they showed up as the above.
Here is the log from the point I enabled trace logging onward. Set channel to 25 and reset controller, shutdown the pc, unplugged/plugged the stick, then started everything up.
2018-06-27 14:45:39.897 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration received (Coordinator).
2018-06-27 14:45:39.898 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Unhandled configuration parameter zigbee_initialise >> true.
2018-06-27 14:45:39.898 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Unhandled configuration parameter zigbee_channel >> 25.
2018-06-27 14:45:39.899 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Unhandled configuration parameter zigbee_panid >> 40903.
2018-06-27 14:45:39.899 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Unhandled configuration parameter zigbee_extendedpanid >> D767A8513BC83A06.
2018-06-27 14:45:39.899 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Unhandled configuration parameter zigbee_networkkey >> 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00.
2018-06-27 14:45:39.905 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Creating ZigBee persistence folder C:\openHAB2\userdata/zigbee
2018-06-27 14:45:39.915 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Start.
2018-06-27 14:45:39.918 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Done.
2018-06-27 14:45:39.919 [DEBUG] [bee.internal.ZigBeeNetworkDiscoverer] - Network discovery task shutdown
2018-06-27 14:45:39.935 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - AshFrameHandler exited.
2018-06-27 14:45:39.934 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port 'COM4' closed.
2018-06-27 14:45:39.937 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - AshFrameHandler close.
2018-06-27 14:45:39.937 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - AshFrameHandler close complete.
2018-06-27 14:45:39.937 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network [zigbee:coordinator_ember:d0f84d4e] closed.
2018-06-27 14:45:39.938 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Initializing ZigBee Ember serial bridge handler.
2018-06-27 14:45:39.938 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initializing ZigBee network [zigbee:coordinator_ember:d0f84d4e].
2018-06-27 14:45:39.938 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Channel 25
2018-06-27 14:45:39.938 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - PANID 40903
2018-06-27 14:45:39.938 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - EPANID D767A8513BC83A06
2018-06-27 14:45:39.939 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2018-06-27 14:45:39.939 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising network
2018-06-27 14:45:39.944 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key String 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2018-06-27 14:45:39.945 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key initialised 79945A97B1E61E37B28E2C3B52A9D1BB
2018-06-27 14:45:39.945 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key final array 79945A97B1E61E37B28E2C3B52A9D1BB
2018-06-27 14:45:39.946 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - ZigBee Ember Coordinator opening Port:'COM4' PAN:9fc7, EPAN:D767A8513BC83A06, Channel:25
2018-06-27 14:45:39.946 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
2018-06-27 14:45:40.947 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2018-06-27 14:45:40.948 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2018-06-27 14:45:40.948 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key initialise 79945A97B1E61E37B28E2C3B52A9D1BB
2018-06-27 14:45:40.948 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP dongle initialize with protocol ASH2.
2018-06-27 14:45:40.949 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Connecting to serial port [COM4] at 57600 baud, flow control FLOWCONTROL_OUT_XONOFF.
2018-06-27 14:45:40.963 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port [COM4] is initialized.
2018-06-27 14:45:40.964 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2018-06-27 14:45:40.965 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - AshFrameHandler thread started
2018-06-27 14:45:40.967 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue: 1
2018-06-27 14:47:18.543 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration received (Coordinator).
2018-06-27 14:47:18.544 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Unhandled configuration parameter zigbee_initialise >> true.
2018-06-27 14:47:18.545 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Unhandled configuration parameter zigbee_channel >> -1.
2018-06-27 14:47:18.545 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Unhandled configuration parameter zigbee_panid >> 40903.
2018-06-27 14:47:18.545 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Unhandled configuration parameter zigbee_extendedpanid >> D767A8513BC83A06.
2018-06-27 14:47:18.546 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Unhandled configuration parameter zigbee_networkkey >> 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00.
2018-06-27 14:47:18.551 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Start.
2018-06-27 14:47:18.553 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Done.
2018-06-27 14:47:18.554 [DEBUG] [bee.internal.ZigBeeNetworkDiscoverer] - Network discovery task shutdown
2018-06-27 14:47:18.558 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - AshFrameHandler exited.
2018-06-27 14:47:18.558 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port 'COM4' closed.
2018-06-27 14:47:18.558 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - AshFrameHandler close.
2018-06-27 14:47:18.559 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - AshFrameHandler close complete.
2018-06-27 14:47:18.559 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network [zigbee:coordinator_ember:d0f84d4e] closed.
2018-06-27 14:47:18.559 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Initializing ZigBee Ember serial bridge handler.
2018-06-27 14:47:18.560 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initializing ZigBee network [zigbee:coordinator_ember:d0f84d4e].
2018-06-27 14:47:18.560 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Channel -1
2018-06-27 14:47:18.560 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - PANID 40903
2018-06-27 14:47:18.560 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - EPANID D767A8513BC83A06
2018-06-27 14:47:18.561 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2018-06-27 14:47:18.561 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising network
2018-06-27 14:47:18.564 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key String 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2018-06-27 14:47:18.567 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key initialised F63C49E2D0D182C96CEA64C279B52220
2018-06-27 14:47:18.568 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key final array F63C49E2D0D182C96CEA64C279B52220
2018-06-27 14:47:18.569 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - ZigBee Ember Coordinator opening Port:'COM4' PAN:9fc7, EPAN:D767A8513BC83A06, Channel:-1
2018-06-27 14:47:18.569 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
2018-06-27 14:47:19.571 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2018-06-27 14:47:19.572 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2018-06-27 14:47:19.572 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key initialise F63C49E2D0D182C96CEA64C279B52220
2018-06-27 14:47:19.572 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP dongle initialize with protocol ASH2.
2018-06-27 14:47:19.573 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Connecting to serial port [COM4] at 57600 baud, flow control FLOWCONTROL_OUT_XONOFF.
2018-06-27 14:47:19.590 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port [COM4] is initialized.
2018-06-27 14:47:19.590 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2018-06-27 14:47:19.591 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - AshFrameHandler thread started
2018-06-27 14:47:19.592 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue: 1
2018-06-27 14:48:30.426 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Configuration received (Coordinator).
2018-06-27 14:48:30.427 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Unhandled configuration parameter zigbee_initialise >> true.
2018-06-27 14:48:30.428 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Unhandled configuration parameter zigbee_channel >> 25.
2018-06-27 14:48:30.428 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Unhandled configuration parameter zigbee_panid >> 40903.
2018-06-27 14:48:30.429 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Unhandled configuration parameter zigbee_extendedpanid >> D767A8513BC83A06.
2018-06-27 14:48:30.430 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: Unhandled configuration parameter zigbee_networkkey >> 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00.
2018-06-27 14:48:30.433 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Start.
2018-06-27 14:48:30.435 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Done.
2018-06-27 14:48:30.436 [DEBUG] [bee.internal.ZigBeeNetworkDiscoverer] - Network discovery task shutdown
2018-06-27 14:48:30.442 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port 'COM4' closed.
2018-06-27 14:48:30.442 [TRACE] [e.ember.internal.ash.AshFrameHandler] - ASH RX: FFFFFFFF
2018-06-27 14:48:30.442 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - AshFrameHandler exited.
2018-06-27 14:48:30.442 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - AshFrameHandler close.
2018-06-27 14:48:30.443 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - AshFrameHandler close complete.
2018-06-27 14:48:30.443 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network [zigbee:coordinator_ember:d0f84d4e] closed.
2018-06-27 14:48:30.444 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Initializing ZigBee Ember serial bridge handler.
2018-06-27 14:48:30.444 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initializing ZigBee network [zigbee:coordinator_ember:d0f84d4e].
2018-06-27 14:48:30.445 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Channel 25
2018-06-27 14:48:30.445 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - PANID 40903
2018-06-27 14:48:30.445 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - EPANID D767A8513BC83A06
2018-06-27 14:48:30.446 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2018-06-27 14:48:30.446 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising network
2018-06-27 14:48:30.449 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key String 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2018-06-27 14:48:30.449 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key initialised D37877E4952531705A50E092F1947FEC
2018-06-27 14:48:30.449 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key final array D37877E4952531705A50E092F1947FEC
2018-06-27 14:48:30.450 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - ZigBee Ember Coordinator opening Port:'COM4' PAN:9fc7, EPAN:D767A8513BC83A06, Channel:25
2018-06-27 14:48:30.451 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
2018-06-27 14:48:31.452 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2018-06-27 14:48:31.452 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2018-06-27 14:48:31.453 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key initialise D37877E4952531705A50E092F1947FEC
2018-06-27 14:48:31.453 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP dongle initialize with protocol ASH2.
2018-06-27 14:48:31.454 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Connecting to serial port [COM4] at 57600 baud, flow control FLOWCONTROL_OUT_XONOFF.
2018-06-27 14:48:31.469 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port [COM4] is initialized.
2018-06-27 14:48:31.470 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2018-06-27 14:48:31.470 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - AshFrameHandler thread started
2018-06-27 14:48:31.471 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue: 1
2018-06-27 14:48:43.859 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2018-06-27 14:58:45.044 [DEBUG] [org.openhab.binding.zigbee.cc2531 ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=114, service.bundleid=200, service.scope=bundle, component.name=org.openhab.binding.zigbee.cc2531.internal.CC2531HandlerFactory, component.id=9} - org.openhab.binding.zigbee.cc2531
2018-06-27 14:58:45.060 [DEBUG] [org.openhab.binding.zigbee.cc2531 ] - BundleEvent STARTING - org.openhab.binding.zigbee.cc2531
2018-06-27 14:58:45.061 [DEBUG] [org.openhab.binding.zigbee.cc2531 ] - BundleEvent STARTED - org.openhab.binding.zigbee.cc2531
2018-06-27 14:58:45.080 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=115, service.bundleid=199, service.scope=bundle, component.name=org.openhab.binding.zigbee.internal.ZigBeeHandlerFactory, component.id=10} - org.openhab.binding.zigbee
2018-06-27 14:58:45.082 [DEBUG] [org.openhab.binding.zigbee ] - BundleEvent STARTING - org.openhab.binding.zigbee
2018-06-27 14:58:45.084 [DEBUG] [org.openhab.binding.zigbee ] - BundleEvent STARTED - org.openhab.binding.zigbee
2018-06-27 14:58:45.098 [DEBUG] [org.openhab.binding.zigbee ] - BundleEvent [unknown:512] - org.openhab.binding.zigbee
2018-06-27 14:58:45.100 [DEBUG] [org.openhab.binding.zigbee.cc2531 ] - BundleEvent [unknown:512] - org.openhab.binding.zigbee.cc2531
2018-06-27 14:58:45.105 [DEBUG] [org.openhab.binding.zigbee.telegesis] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.usbserial.UsbSerialDiscoveryParticipant}={service.id=116, service.bundleid=202, service.scope=bundle, component.name=org.openhab.binding.zigbee.telegesis.internal.discovery.ZigBeeTelegesisUsbSerialDiscoveryParticipant, component.id=11} - org.openhab.binding.zigbee.telegesis
2018-06-27 14:58:45.108 [DEBUG] [org.openhab.binding.zigbee.telegesis] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=117, service.bundleid=202, service.scope=bundle, component.name=org.openhab.binding.zigbee.telegesis.internal.TelegesisHandlerFactory, component.id=12} - org.openhab.binding.zigbee.telegesis
2018-06-27 14:58:45.110 [DEBUG] [org.openhab.binding.zigbee.telegesis] - BundleEvent STARTING - org.openhab.binding.zigbee.telegesis
2018-06-27 14:58:45.111 [DEBUG] [org.openhab.binding.zigbee.telegesis] - BundleEvent STARTED - org.openhab.binding.zigbee.telegesis
2018-06-27 14:58:45.114 [DEBUG] [org.openhab.binding.zigbee.telegesis] - BundleEvent [unknown:512] - org.openhab.binding.zigbee.telegesis
2018-06-27 14:58:45.118 [DEBUG] [org.openhab.binding.zigbee.xbee ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=118, service.bundleid=203, service.scope=bundle, component.name=org.openhab.binding.zigbee.xbee.internal.XBeeHandlerFactory, component.id=13} - org.openhab.binding.zigbee.xbee
2018-06-27 14:58:45.156 [DEBUG] [org.openhab.binding.zigbee.xbee ] - BundleEvent STARTING - org.openhab.binding.zigbee.xbee
2018-06-27 14:58:45.157 [DEBUG] [org.openhab.binding.zigbee.xbee ] - BundleEvent STARTED - org.openhab.binding.zigbee.xbee
2018-06-27 14:58:45.160 [DEBUG] [org.openhab.binding.zigbee.xbee ] - BundleEvent [unknown:512] - org.openhab.binding.zigbee.xbee
2018-06-27 14:58:45.557 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-06-27 14:58:45.624 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-06-27 14:58:48.225 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.112:8080
2018-06-27 14:58:48.226 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.112:8443
2018-06-27 14:58:52.981 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-06-27 14:58:53.469 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model '(1)_lighton.rules' has errors, therefore ignoring it: [13,1]: no viable alternative at input 'then'
[14,14]: no viable alternative at input 'Item'
[14,22]: extraneous input ')' expecting 'end'
2018-06-27 14:58:54.337 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-06-27 14:58:54.379 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-06-27 14:58:54.402 [INFO ] [sysfs.internal.SysfsUsbSerialScanner] - Cannot perform scans with this configuration: sysfsTtyDevicesDirectory: /sys/class/tty, devDirectory: /dev
2018-06-27 14:58:54.408 [INFO ] [sfs.internal.PollingUsbSerialScanner] - Do not start background scanning, as the configured USB-Serial scanner cannot perform scans on this system
2018-06-27 14:58:54.409 [INFO ] [sfs.internal.PollingUsbSerialScanner] - Do not start background scanning, as the configured USB-Serial scanner cannot perform scans on this system
2018-06-27 14:58:54.621 [DEBUG] [com.zsmartsystems.zigbee ] - BundleEvent STARTING - com.zsmartsystems.zigbee
2018-06-27 14:58:54.624 [DEBUG] [com.zsmartsystems.zigbee ] - BundleEvent STARTED - com.zsmartsystems.zigbee
2018-06-27 14:58:54.627 [DEBUG] [m.zsmartsystems.zigbee.dongle.cc2531] - BundleEvent STARTING - com.zsmartsystems.zigbee.dongle.cc2531
2018-06-27 14:58:54.628 [DEBUG] [m.zsmartsystems.zigbee.dongle.cc2531] - BundleEvent STARTED - com.zsmartsystems.zigbee.dongle.cc2531
2018-06-27 14:58:54.630 [DEBUG] [om.zsmartsystems.zigbee.dongle.ember] - BundleEvent STARTING - com.zsmartsystems.zigbee.dongle.ember
2018-06-27 14:58:54.633 [DEBUG] [om.zsmartsystems.zigbee.dongle.ember] - BundleEvent STARTED - com.zsmartsystems.zigbee.dongle.ember
2018-06-27 14:58:54.634 [DEBUG] [smartsystems.zigbee.dongle.telegesis] - BundleEvent STARTING - com.zsmartsystems.zigbee.dongle.telegesis
2018-06-27 14:58:54.636 [DEBUG] [smartsystems.zigbee.dongle.telegesis] - BundleEvent STARTED - com.zsmartsystems.zigbee.dongle.telegesis
2018-06-27 14:58:54.637 [DEBUG] [com.zsmartsystems.zigbee.dongle.xbee] - BundleEvent STARTING - com.zsmartsystems.zigbee.dongle.xbee
2018-06-27 14:58:54.638 [DEBUG] [com.zsmartsystems.zigbee.dongle.xbee] - BundleEvent STARTED - com.zsmartsystems.zigbee.dongle.xbee
2018-06-27 14:58:54.641 [DEBUG] [org.openhab.binding.zigbee.ember ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.usbserial.UsbSerialDiscoveryParticipant}={service.id=324, service.bundleid=201, service.scope=bundle, component.name=org.openhab.binding.zigbee.ember.internal.discovery.ZigBeeEmberUsbSerialDiscoveryParticipant, component.id=202} - org.openhab.binding.zigbee.ember
2018-06-27 14:58:54.652 [DEBUG] [org.openhab.binding.zigbee.ember ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=325, service.bundleid=201, service.scope=bundle, component.name=org.openhab.binding.zigbee.ember.internal.EmberHandlerFactory, component.id=203} - org.openhab.binding.zigbee.ember
2018-06-27 14:58:54.661 [DEBUG] [org.openhab.binding.zigbee.ember ] - BundleEvent STARTING - org.openhab.binding.zigbee.ember
2018-06-27 14:58:54.662 [DEBUG] [org.openhab.binding.zigbee.ember ] - BundleEvent STARTED - org.openhab.binding.zigbee.ember
2018-06-27 14:58:54.737 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2018-06-27 14:58:54.740 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Creating ZigBee discovery service for zigbee:coordinator_ember:d0f84d4e
2018-06-27 14:58:54.741 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Activating ZigBee discovery service for zigbee:coordinator_ember:d0f84d4e
2018-06-27 14:58:54.742 [DEBUG] [org.openhab.binding.zigbee.ember ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=333, service.bundleid=201, service.scope=singleton} - org.openhab.binding.zigbee.ember
2018-06-27 14:58:54.823 [DEBUG] [org.openhab.binding.zigbee.ember ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.firmware.FirmwareUpdateHandler}={service.id=334, service.bundleid=201, service.scope=singleton} - org.openhab.binding.zigbee.ember
2018-06-27 14:58:58.060 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - Initializing ZigBee Ember serial bridge handler.
2018-06-27 14:58:58.063 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initializing ZigBee network [zigbee:coordinator_ember:d0f84d4e].
2018-06-27 14:58:58.064 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Channel 25
2018-06-27 14:58:58.066 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - PANID 40903
2018-06-27 14:58:58.066 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - EPANID D767A8513BC83A06
2018-06-27 14:58:58.073 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port 'COM3'
2018-06-27 14:58:58.074 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2018-06-27 14:58:58.075 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key String 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2018-06-27 14:58:58.078 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key initialised 6C31BE1E5F6D772FF55E04443C06A078
2018-06-27 14:58:58.079 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key final array 6C31BE1E5F6D772FF55E04443C06A078
2018-06-27 14:58:58.093 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2018-06-27 14:58:58.099 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2018-06-27 14:58:58.111 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2018-06-27 14:58:58.111 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2018-06-27 14:58:58.120 [DEBUG] [ng.zigbee.ember.handler.EmberHandler] - ZigBee Ember Coordinator opening Port:'COM4' PAN:9fc7, EPAN:D767A8513BC83A06, Channel:25
2018-06-27 14:58:58.124 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
2018-06-27 14:58:59.125 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2018-06-27 14:58:59.126 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2018-06-27 14:58:59.149 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Key initialise 6C31BE1E5F6D772FF55E04443C06A078
2018-06-27 14:58:59.151 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP dongle initialize with protocol ASH2.
2018-06-27 14:58:59.155 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Connecting to serial port [COM4] at 57600 baud, flow control FLOWCONTROL_OUT_XONOFF.
2018-06-27 14:58:59.170 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port [COM4] is initialized.
2018-06-27 14:58:59.186 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - AshFrameHandler thread started
2018-06-27 14:58:59.187 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameRst []
2018-06-27 14:58:59.205 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue: 1
2018-06-27 14:59:01.211 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2018-06-27 14:59:01.212 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
2018-06-27 14:59:01.212 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2018-06-27 14:59:01.212 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2018-06-27 14:59:01.213 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2018-06-27 14:59:01.213 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 2
2018-06-27 14:59:01.213 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
