Oh, I see. Yes, there was a perl program. Here it is :
pollClimateTalk.py:
import socket
import sys
import datetime
import time
import pygame
from pygame.locals import *
# Create a TCP/IP socket
sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
w, h = 8, 16
SessionID = [[0 for x in range(w)] for y in range(h)]
MacID = [[0 for x in range(w)] for y in range(h)]
quitapp=0
outdoortemp=0
# Connect the socket to the port where the server is listening
#server_address = ('192.168.1.167', 23)
#server_address = ('50.246.121.173', 8023)
server_address = ('10.88.64.134', 23)
print 'connecting to %s port %s\r\n' % server_address,
pygame.init()
pygame.display.set_mode((100,100))
print 'Press ESC in the black open window form to quit\r\n',
state=0 # 0=sync, else decode
oldstate=state+1
try:
while quitapp==0:
for event in pygame.event.get():
if event.type == QUIT: sys.exit()
if event.type == KEYDOWN and event.dict['key'] == 27:
quitapp=1
pygame.event.pump()
if state==0:
if oldstate!=state:
print "Opening Socket\r\n",
oldstate=state
try:
sock.connect(server_address)
state=1
except socket.error as msg:
#time.sleep(10)
oldstate=state+1 #reprint Opening info
continue
if state==1:
if oldstate!=state:
print "Sync Begin\r\n",
oldstate=state
seqcnt = 0 # 0=looking for $A0, 1=looking for $11, 2 thru 2+$11+2=waiting to finish sync
try:
# get in sync, look for $A0 then $11, then wait $11+2 bytes
data = sock.recv(1)
print data.encode('hex'),
if seqcnt>=20:
print '\r\nsync finished\r\n',
state=2
else:
if seqcnt>=2:
seqcnt+=1
else:
if seqcnt==1:
if data[0]==chr(0x11):
seqcnt+=1
else:
seqcnt=0
else: #if seqcnt==0:
if data[0]==chr(0xA0):
seqcnt+=1
else:
seqcnt=0
socket.close()
state=0
if state==2:
if oldstate!=state:
print "Decode Begin\r\n",
oldstate=state
seqcnt=0
payload=0
command=bytearray()
heatstart=heatend=0
coolstart=coolend=0
fanstart=fanend=0
altheatstart=altheatend=0
heaton=coolon=fanon=altheaton=0
try:
data = sock.recv(1)
#if ord(data[0])!=0xFF or payload==2 or payload==1: # or len(command)>=8:
if True:
command.append(data[0])
if seqcnt>9:
seqcnt+=1
if payload>0:
payload-=1
if payload==0:
lrc1 = 0xAA
lrc2 = 0
for b in command:
lrc1 += b
if lrc1>= 255:
lrc1 -= 255
lrc2 += lrc1
if lrc2>= 255:
lrc2 -= 255
if lrc1!=0:
state=1 # resync
print datetime.datetime.now().strftime("%Y-%m-%d %H:%M:%S "),
print '(%02x,%02x) ' % (lrc1,lrc2),
print ' '.join('{:02x}'.format(x) for x in command),
command[8]=0xFF #dummy command
continue
if (command[8]&0x80)==0:
if command[7]!=0x79: #don't print the NODE queries
if len(command)>0:
#else:
# print "NODE query",
if command[7]==0xF9:
print "NODEDISCOVERY reply",
if command[7]==0x7A:
print "SETADDR request",
if command[7]==0xFA:
print "SETADDR reply",
if command[7]==0x7B:
print "GETNODEID request",
if command[7]==0xFB:
print "GETNODEID reply",
if command[7]==0x14:
print "NODELST request",
if command[7]==0x94:
print "NODELST reply",
if command[7]==0x02:
print "GETSTATUS request",
if command[7]==0x82:
print "GETSTATUS reply",
if command[7]==0x01:
print "GETCFG request",
if command[7]==0x81:
print "GETCFG reply",
if command[7]==0x05:
print "DIAG request",
if command[7]==0x85:
print "DIAG reply",
if command[7]==0x07:
print "OAT request",
if command[7]==0x87:
val=(command[13]&0x3F)*16
val+=(command[12]>>4)
frac=((command[12]&0x0f)*10)/16
outdoortemp=val
if (command[13]&0x40)>0:
outdoortemp*=-1
val*=-1
print "OAT reply %d.%dF" % (val,frac),
if command[7]==0x03:
if command[10]==0x69:
print "AltHeat request ",
val=command[13]/2
if val==0:
if altheaton==1:
altheaton=0
print("OFF,OAT={}F,".format(int(outdoortemp))),
#altheatend = time.time()
#if altheatstart==0: altheatstart=altheatend
#hours, rem = divmod(altheatend-altheatstart, 3600)
#minutes, seconds = divmod(rem, 60)
#if seconds>(60-minutes*2): minutes+=1
#print("OnDuration={:0>2}:{:0>2}".format(int(hours),int(minutes))),
else:
print "%d%%," % val,
if altheaton==0:
altheaton=1
#altheatstart=time.time()
#if altheatend==0: altheatend=altheatstart
#hours, rem = divmod(altheatstart-altheatend, 3600)
#print("OffDuration={:0>2}:{:0>2}".format(int(hours),int(minutes))),
if command[10]==0x66:
print "Fan request ",
val=command[14]/2
if val==0:
if fanon==1:
fanon=0
#fanend = time.time()
#if fanstart==0: fanstart=fanend
#hours, rem = divmod(fanend-fanstart, 3600)
else:
if fanon==0:
fanon=1
#fanstart=time.time()
#if fanend==0: fanend=fanstart
#hours, rem = divmod(fanstart-fanend, 3600)
if command[10]==0x65:
print "Cool request",
val=command[13]/2
if val==0:
if coolon==1:
coolon=0
#coolend = time.time()
#if coolstart==0: coolstart=coolend
#hours, rem = divmod(coolend-coolstart, 3600)
else:
if coolon==0:
coolon=1
#coolstart=time.time()
#if coolend==0: coolend=coolstart
#hours, rem = divmod(coolstart-coolend, 3600)
if command[10]==0x64:
print "Heat request",
val=command[13]/2
if val==0:
if heaton==1:
heaton=0
#heatend = time.time()
#if heatstart==0: heatstart=heatend
#hours, rem = divmod(heatend-heatstart, 3600)
else:
if heaton==0:
heaton=1
#heatstart=time.time()
#if heatend==0: heatend=heatstart
#hours, rem = divmod(heatstart-heatend, 3600)
if command[7]==0x83:
print "ACK reply",
print '\r\n',
else:
# test
#print datetime.datetime.now().strftime("%Y-%m-%d %H:%M:%S "),
#print '(%02x,%02x) ' % (lrc1,lrc2),
#print ' '.join('{:02x}'.format(x) for x in command),
#print '\r\n',
if command[6]<10 :
device=command[6]&0x0F # get deviceID
match=1
if len(command)>=27 and command[8]==0xA0:
for x in range(0,8):
if SessionID[device][x]!=command[19+x]:
match=0
if match==0:
# test
#print 'Old SessionID[%d] ' % device,
#for x in range(0,8):
# print "%02X" % SessionID[device][x],
#print '\r\n',
print 'New SessionID[%d] ' % device,
SessionID[device][x]=command[19+x]
print '\r\n',
match=1
if MacID[device][x]!=command[11+x]:
match=0
if match==0:
print 'New MacID[%d] ' % device,
MacID[device][x]=command[11+x]
print "%02X" % MacID[device][x],
print '\r\n',
#cmdlen=len(command)
#for x in range(0,cmdlen):
# command.pop(0)
command=bytearray()
seqcnt=0
else:
if seqcnt==9:
payload=ord(data[0])+2
seqcnt+=1
#print data.encode('hex'),
else:
seqcnt+=1
socket.close()
state=0
finally:
print >>sys.stderr, 'closing socket\r\n',
sock.close()
