Also works here! Thanks!
Same here - many thanks!!
Great, i’ll let it run today the submit a PR. Just fyi if you installed from the CLI its likely a reboot or upgrade will reset the binding to the distro version until i submit this upstream. If its in the addons folder, then thats not a problem, but you should remove that once the upstream fix is in and install normally.
Well i just got banned again, going to let it sit, then change the poll cycle to 5 mins and see what happens
I have 300s interval set and am not yet banned. Will report tomorrow
So far so good. What’s your experience?
I was banned for several hours and went to bed ;-). i just enabled it again now and will let it run, but i’m glad its working so far! I will probably enforce a 5 min floor for poll interval, anything lower and we get banned i think, plus I don’t want openHAB to be an issue for them.
It’s running good so far since 24h
Merry Christmas
