I have an audio-player, and I want it to stop, when song ends, not in the middle of the song.
I want to create a rule, which checks the item state (track_duration), and if the state reaches a certain value (0), execute actions on other items (send stop to player,switch smartplug off).
In other words:
-> if stop signal detected -> detect track_duration and wait for “0” -> stop player -> switch smartplug off
But I don’t know the syntax or even the action to use… I was thinking about “while” but can’t figure out how to do it - anyone??
My main problem is I don’t know how to tell openhab to wait for the value.
I think I have to explain this alittle more to you, because I don’t have the ability to do it like this…
I have a rule, that fires up lights and music to a room with a 45mins timer.
When the timer has expired, the music shouldn’t stop immediately but when the actual track is over.
rule "Gym Time Launch"
Item GymTime received command ON
if ( GymTime.state = ON ) {
logInfo("Actions", "Gym-Time started already, doing nothing ")
return;
gymTimer?.cancel
Smartplug01Switch.sendCommand("ON")
SqueezeGymPlayFavorite.sendCommand("21")
if ( RGBBulb03Switch.state != ON ) {
RGBBulb03Switch.sendCommand("ON")
gymTimer = createTimer(now.plusMinutes(45)) [ |
--------->> this is where the magic should happen <<-----------
RGBBulb03Switch.sendCommand("OFF")
SqueezeGymPower.sendCommand("OFF")
GymTime.sendCommand("OFF")
gymTimer = null
Smartplug01Switch.sendCommand("OFF")
rule "Gym Time Cancel"
Item GymTime received command OFF
------------------->> and here ;) <<------------------------
gymTimer = null
I hope I don’t confuse you too much with that, sorry…
You’d would need your 45 minute timer to be referenced by a global variable, so that any other rule in the same rule file can “see” it.
Looks like you already do that - gymTimer ?
This variable is null when the timer is not running.
Now make a rule that runs every time the track duration changes to 0
This rule then looks to see if the timer is null.
If it is, the timer has finished and you do whatever.
If it is not null, the timer is still running and presumably you do nothing.
ahh ok I see… but the duration can not be the trigger of the rule I think, because if there’s music in this room not fired by this specific timer, it would stop after every track and I have to avoid this…
Thanks for your effort
Any further suggestions maybe?
You get what you ask for, so be sure to give the whole story, it will save you time.
So, to have the rule take effect only when the timer has expired, and not to interfere unless the timer has been used.
Alter your timer so that it does NOT set its own handle to null at execution time.
Alter the rule that runs every time duration changes to 0
Instead of timer===null , look for timer.hasTerminated as the prerequisite for “doing whatever”
Add a line to the whatever to set the time handle to null, now that it is finished with.
In real life you’ll get into this rule and test when the timer handle is null, but you cannot test the hasTerminated property of null, it hasn’t got one.
The actual test you’d need - if (myTimer !== null && myTimer.hasTerminated) {
will avoid errors, it will bail out early when null.
