No reboot, no update no file change but today I came home and all my habpanel where weird …so I check the config and realize I only have local config … WHY ?? is there a way the get thing back ?
I try to restart oprnhab but it does nothing
I had the same thing happen to me. My local storage was up to date on one machine, so I saved that local storage to a new panel configuration, but I also have no idea what happened.
I was changing other configuration, adding in a new module for a NetAtmo weather station, but I didn’t update OH2 packages or anything like that, so it was a surprise.
Unfortunately, I had no way to repeat it, so I have no way to really log an issue; It happened, I saved a local config, and it has been back working ever since.
I realise that most of my config wasn’t to hard to recreate but now I made a backup off everything !!
would this be the case ?
Just had the same problem : all configuration including custom panels lost after I changed the IP address and hostname of the computer openhab is running on.
Any chance of rescuing any of these settings ?
Try changing the IP/hostname back to previous state.
Browser’s local storage will keep all your HABPanel data.
After that remember to export your Panel configuration to file.
http://youropenhab:8080/habpanel/index.html#/settings/localconfig
Then change your hostname again and import your settings here:
http://yourNEWopenhab:8080/habpanel/index.html#/settings/localconfig
@ysc would it make sense to point that in the docs?
openHABian makes it possible to change hostname easily.
Hope that helps.
Cheers!
