Now that I have a better understanding of groups, I’m having an issue making it work.
In my items file I have the following:
Group gLights
Switch Corner "Breakfast" [ "Switchable" ] (gLights) {channel="zwave:device:ad34b696:node2:switch_binary"}
Switch All_Off "Everything" [ "Switchable" ] (gLights) { autoupdate="false",tcp=">[ON:10.5.1.6:3040:'MAP(off.map)'],>[OFF:10.5.1.6:3040:'MAP(off.map)']"}
Group:Switch:OR(ON,OFF) gLights "House" [ "Switchable" ]
In my sitemap file I have
Switch item=All_Off mappings=[ON="Go!"]
Switch item=House mappings=[ON="Turn House Off"]
Yet these switches do not fire…the All_Off one previously worked before I added it to the group gLights
In the log I see…
2017-05-06 11:15:36.814 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'All_Off' for widget org.eclipse.smarthome.model.sitemap.Switch
2017-05-06 11:15:36.815 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'All_Off' for widget org.eclipse.smarthome.model.sitemap.Switch
2017-05-06 11:15:36.815 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2017-05-06 11:15:36.815 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'House' for widget org.eclipse.smarthome.model.sitemap.Switch
It may be something simple but I’m just not seeing what it is…
Any suggestions?
