I am not interested to seeing all the output only Reachable :true and IP :192.168.0.111
I would appreciate advice on how to set it up in the item’s channel or even through a rule
thanks
I’m pretty sure that IP is fix (it’s the name of the node)
To get the Reachable information into an Item (switch would be fine?) You’ll have to change some settings for the mqtt channel.
- id: living
channelTypeUID: mqtt:switch
label: Living room reachable
description: ""
configuration:
stateTopic: tele/livingroom/RESULT
transformationPattern: JSONPATH:$.Ping["192.168.0.111"].Reachable
off: "false"
on: "true"
If the ip will change from time to time, you can use this JSONPATH instead:
JSONPATH:$.Ping[0].Reachable
And creating another channel to get the current ip is easy enough (has to be a string channel, of course).
