I/O Error comes back every time I set up a new system...driving me nuts
Hi there,
ever since I am using OH 2.2 I am experiencing different errors on OH, most of the time beginning with a I/O Error. This lookes f.e. like this:
[16:57:04] openhabian@openhabianpi:~$ tail -f /var/log/openhab2/openhab.log
2018-09-05 16:54:57.349 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2018-09-05 16:55:00.463 [WARN ] [ve.internal.protocol.ZWaveController] - TODO: Implement processing of Request Message = -- (0x0A)
2018-09-05 16:55:00.659 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2018-09-05 16:55:00.662 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
2018-09-05 16:55:00.666 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2018-09-05 16:55:00.669 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2018-09-05 16:55:00.672 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2018-09-05 16:55:00.675 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 2
2018-09-05 16:55:00.677 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2018-09-05 16:55:08.636 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 2: Already processed another send data request for this callback Id, ignoring.
2018-09-05 16:57:35.306 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: org.eclipse.jetty.io.EofException
        at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) [163:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [163:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [163:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [163:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [163:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [163:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [163:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [160:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [160:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [160:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [160:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [160:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
        at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [78:org.eclipse.jetty.servlet:9.3.21.v20170918]
        at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [78:org.eclipse.jetty.servlet:9.3.21.v20170918]
        at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [175:org.ops4j.pax.web.pax-web-jetty:6.0.9]
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [77:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [75:org.eclipse.jetty.security:9.3.21.v20170918]
        at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [77:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [77:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [175:org.ops4j.pax.web.pax-web-jetty:6.0.9]
        at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [78:org.eclipse.jetty.servlet:9.3.21.v20170918]
        at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [77:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [77:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [77:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [175:org.ops4j.pax.web.pax-web-jetty:6.0.9]
        at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [77:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.Server.handle(Server.java:534) [77:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [77:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [77:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [69:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [69:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [69:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [80:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [80:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [80:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [80:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [80:org.eclipse.jetty.util:9.3.21.v20170918]
Caused by: org.eclipse.jetty.io.EofException
        at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:199) ~[69:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:420) ~[69:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:313) ~[69:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:147) ~[69:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:731) ~[77:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[80:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224) ~[80:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:519) ~[77:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:745) ~[77:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:801) ~[77:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:235) ~[77:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:219) ~[77:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:496) ~[77:org.eclipse.jetty.server:9.3.21.v20170918]
        at java.io.OutputStream.write(OutputStream.java:75) ~[?:?]
        at org.glassfish.jersey.servlet.internal.ResponseWriter$NonCloseableOutputStreamWrapper.write(ResponseWriter.java:320) ~[?:?]
        at org.glassfish.jersey.message.internal.CommittingOutputStream.write(CommittingOutputStream.java:218) ~[?:?]
        at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$UnCloseableOutputStream.write(WriterInterceptorExecutor.java:294) ~[?:?]
        at org.eclipse.smarthome.io.rest.core.internal.GsonProvider.writeTo(GsonProvider.java:71) ~[?:?]
        at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.invokeWriteTo(WriterInterceptorExecutor.java:265) ~[?:?]
        at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.aroundWriteTo(WriterInterceptorExecutor.java:250) ~[?:?]
        at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[?:?]
        at org.glassfish.jersey.server.internal.JsonWithPaddingInterceptor.aroundWriteTo(JsonWithPaddingInterceptor.java:106) ~[?:?]
        at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:86) ~[?:?]
        ... 46 more
Caused by: java.io.IOException: Broken pipe
        at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:?]
        at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:?]
        at sun.nio.ch.IOUtil.write(IOUtil.java:148) ~[?:?]
        at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:504) ~[?:?]
        at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:179) ~[69:org.eclipse.jetty.io:9.3.21.v20170918]
        ... 46 more
^[OB2018-09-05 16:57:35.306 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
Now, as I have experienced this already a couple of times with 2.2 and 2.3 stable, running 2 different RPI’s (3B Model) with entirely different (new and old) SD Cards. I even bought a brand new RPI3b+ with annother new SD Card and installed the 2.4 nightly, hoping this would fix it finally. Still no luck. I am running out of ideas what to do to fix that stuff finally. Any ideas would be appreciated as this drives me nuts.
I am running the following bindings:
KNX1, Zwave, MQTT, Hue, HTTP1, NTP, Astro, Weatherunderground, Telegram-Action and MQTT-Action
Connection to the KNX bus is via a Enertex Router, The Zwave one is connected through a ZMEEUZB1.
Interestingly enough: I have moved my working configuration to the new RPI and the RRD4J has stopped logging data as well. Maybe just not my day…or week…or century, I don’t know.
Frank
Do you notice anything not working after experiencing this error? Since it comes from jetty I would expect it to manifest itself with something in one of the web UIs or REST API not working.
When does it occur? Periodically with no discernible pattern? Only during startup? Only when interacting with OH through one of the UIs?
Hi Rich,
thanks for your thoughts… I have started to switch off some bindings to see if this makes any difference. So far I started with the HTTP Binding, which is usually used to read my Hue Motion Sensors via HTTP GET. Reason to suspect this binding first is, that OH was disconnecting from the Hue bridge twice witin the last two days, which it never did before. Maybe the polling interval kills the HTTP communication…
Keep you updates, thanks so far.
Cu
Frank
So far, i still have a ton of error Messages in the log for no obvious reason. What changed though, since I disabled the HTTP GET, at least the I/O Errors are gone.
Something with FireMotD seems to be broken as well, could there be a link ?
$ git clone https://github.com/OutsideIT/FireMotD /opt/FireMotD
Cloning into '/opt/FireMotD'...
remote: Counting objects: 943, done.
remote: Compressing objects: 100% (76/76), done.
remote: Total 943 (delta 52), reused 33 (delta 16), pack-reused 851
Receiving objects: 100% (943/943), 15.43 MiB | 7.49 MiB/s, done.
Resolving deltas: 100% (525/525), done.
$ bash /opt/FireMotD/FireMotD -S
2018-09-06 16:24:39,600: FireMotD: Error: Template folder doesn't exist. Upgrading from an older version? Please run make again or run the install function "FireMotD -I -v".
OK
Unless you have been pulling the power on this RPi without shutting it down or are using an older SD card which is wearing out it is unlikely that anything going on with FireMotD would be related to the problems in OH.
So far you have only mentioned the I/O error. What are the other errors?
Too much to count; I have posted several lines in my first post :slight_smile:
So it runs for a while, then all of a sudden there are hundreds of lines in the log like the ones above. Not sure where to start with Posting here?
Now I wanted to install a Fresh copy of openhabian. Downloaded the Image, wrote it to a new SD Card, booted it and…boom…my usual luck is in Action:
2018-03-13_22:53:36_UTC [openHABian] Starting the openHABian initial setup.
2018-03-13_22:53:36_UTC [openHABian] Storing configuration... OK
2018-03-13_22:53:36_UTC [openHABian] Changing default username and password... OK
2018-03-13_22:53:37_UTC [openHABian] Setting up Ethernet connection... OK
2018-03-13_22:53:37_UTC [openHABian] Ensuring network connectivity... OK
2018-03-13_22:53:39_UTC [openHABian] Waiting for dpkg/apt to get ready... OK
2018-09-06_14:54:10_UTC [openHABian] Updating repositories and upgrading installed packages... FAILED
2018-09-06_14:54:56_UTC [openHABian] Initial setup exiting with an error!
I don’t get it…even when I am not doing ANYTHING, still SOMETHING breaks :frowning:
Does this tell you just anything? I am lost here…
login as: openhabian
openhabian@192.168.1.50's password:
Linux openhabianpi 4.14.62-v7+ #1134 SMP Tue Aug 14 17:10:10 BST 2018 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu Sep  6 17:21:21 2018 from 192.168.1.83
################# openhabianpi ################################################
##             Ip = 192.168.1.50
##        Release = Raspbian GNU/Linux 9 (stretch)
##         Kernel = Linux 4.14.62-v7+
##       Platform = Raspberry Pi 3 Model B Rev 1.2
##         Uptime = 0 day(s). 0:0:50
##      CPU Usage = 37.88 % avg over 4 cpu(s)  (4 core(s) x 1 socket(s))
##       CPU Load = 1m: 1.42, 5m: 0.41, 15m: 0.14
##         Memory = Free: 0.45GB (47%), Used: 0.50GB (53%), Total: 0.95GB
##           Swap = Free: 0.09GB (100%), Used: 0.00GB (0%), Total: 0.09GB
##           Root = Free: 11.53GB (82%), Used: 2.38GB (18%), Total: 14.53GB
##        Updates = 0 apt updates available.
##       Sessions = 1 sessions
##      Processes = 111 running processes of 32768 maximum processes
              Welcome to            __  _____    ____  _
            ____  ____  ___  ____  / / / /   |  / __ )(_)___ _____
           / __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __  / / __ `/ __ \
          / /_/ / /_/ /  __/ / / / __  / ___ |/ /_/ / / /_/ / / / /
          \____/ .___/\___/_/ /_/_/ /_/_/  |_/_____/_/\__,_/_/ /_/
              /_/
                  openHAB 2.3.0-1 (Release Build)
Looking for a place to get started? Check out 'sudo openhabian-config' and the
documentation at https://www.openhab.org/docs/installation/openhabian.html
The openHAB dashboard can be reached at http://openhabianpi:8080
To interact with openHAB on the command line, execute: 'openhab-cli --help'
[17:32:34] openhabian@openhabianpi:~$ tail -f /var/log/openhab2/openhab.log
2018-09-06 17:32:30.001 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'shutter.items'
2018-09-06 17:32:30.322 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'light_and_power.items'
2018-09-06 17:32:31.003 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'measurement.items'
2018-09-06 17:32:31.437 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'heating.items'
2018-09-06 17:32:31.575 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.items'
2018-09-06 17:32:31.913 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'weather.items'
2018-09-06 17:32:32.643 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'status.items'
2018-09-06 17:32:33.642 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2018-09-06 17:32:33.690 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
2018-09-06 17:32:37.011 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-09-06 17:32:43.663 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'windows_telegram.rules'
2018-09-06 17:32:43.992 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'washing_machine_state.rules' has errors, therefore ignoring it: [5,80]: missing ')' at '$tH'
[5,83]: mismatched input ':' expecting 'end'
2018-09-06 17:32:47.197 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'lighting.rules'
2018-09-06 17:32:53.300 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'scenes.rules'
2018-09-06 17:32:54.416 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'automation.rules'
2018-09-06 17:32:55.321 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'shutters_telegram.rules'
2018-09-06 17:32:55.364 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.rules'
2018-09-06 17:32:56.107 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'test.rules' is either empty or cannot be parsed correctly!
2018-09-06 17:32:56.980 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'zuhause.sitemap'
2018-09-06 17:32:57.976 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'astro:sun:local' to inbox.
2018-09-06 17:32:58.018 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'astro:moon:local' to inbox.
2018-09-06 17:32:58.953 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:local
2018-09-06 17:32:59.169 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:sun:local every 300 seconds
2018-09-06 17:32:59.451 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:local
2018-09-06 17:32:59.531 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:sun:local every 300 seconds
2018-09-06 17:32:59.572 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:local
2018-09-06 17:32:59.619 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:moon:local every 300 seconds
2018-09-06 17:32:59.783 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:local
2018-09-06 17:32:59.799 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:moon:local every 300 seconds
2018-09-06 17:33:04.572 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been started
2018-09-06 17:33:04.851 [INFO ] [nx.internal.connection.KNXConnection] - Established connection to KNX bus on 224.0.23.12:3671 in mode ROUTER.
2018-09-06 17:33:04.898 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2018-09-06 17:33:04.901 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mybroker'
2018-09-06 17:33:07.982 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-09-06 17:33:08.324 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-09-06 17:33:08.671 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2018-09-06 17:33:08.850 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-09-06 17:33:14.956 [INFO ] [ternal.scheduler.WeatherJobScheduler] - Starting and scheduling weatherJob-home with interval of 30 minutes
2018-09-06 17:33:16.961 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'washing_machine_state.rules'
2018-09-06 17:33:19.842 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2018-09-06 17:33:26.147 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'hue:0210:0017886793e2:9' to inbox.
2018-09-06 17:33:45.049 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
        at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
        at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
        at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [84:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.3.21.v20170918]
        at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [84:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [84:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
        at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
        at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [84:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [84:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [84:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
        at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [84:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.Server.handle(Server.java:534) [84:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [84:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [84:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [76:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [76:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [76:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [87:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [87:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [87:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [87:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [87:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:199) ~[76:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:420) ~[76:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:313) ~[76:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:147) ~[76:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:731) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[87:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224) ~[87:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:519) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:745) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:801) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:235) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:219) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:496) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
        ... 46 more
Caused by: java.io.IOException: Datenübergabe unterbrochen (broken pipe)
        at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:179) ~[76:org.eclipse.jetty.io:9.3.21.v20170918]
        ... 46 more
Your first post shows one I/O error and part of another I/O error. Anything that doesn’t start with the date and time and [ LEVEL ] belongs to the same log statement. So everything between
and
is one error. And since these two errors occur immediately after each other they are essentially the same error. One error because the remote connection cuts the connection abruptly and the other because the output connect also got cut abruptly at the same time.
Post the first line of each different error type. I may need the stack trace later but let’s just start with what the errors are.
You have a syntax error in washing_machine_state.rules file on line 5 column 83. The : at that location is not allowed.
test.rules is an empty file or so completely mangled that OH cannot even recognize it as a .rules file.
Everything else was loaded and parsed correctly.
Your Astro events were scheduled.
HTTP binding started polling whatever URLs you have configured in http.cfg.
MQTT connected to the broker.
All your UIs started.
Wunderground started (you may want to remove your API key from the posting).
And now you see the same I/O error. You mentioned before that you had removed your HTTP configs but you still have the binding enabled and it will be polling the URLs configured in http.cfg. This does look like it might be the HTTP binding and the error is caused because whatever you are connecting to is not responding in time and the connection just gets cut without returning any data.
Checked everything you highlighted:
Test rule is gone
washing machine rule corrected
The HTTP Binding is no longer there, all references to this have been removed.
The following entries are totally puzzeling me. HTTP.CONF is gone as well, so why is OH stil trying to talk to the Hue bridge’s API (after a reboot)?
2018-09-03 17:54:25.895 [ERROR] [org.openhab.io.net.http.HttpUtil    ] - Fatal transport error: java.net.ConnectException: Verbindungsaufbau abgelehnt (Connection refused)
2018-09-03 17:54:25.903 [ERROR] [ab.binding.http.internal.HttpBinding] - No response received from 'http://192.168.1.55/api/hAhvO6BFxsmEF-Fzfa5sxrc5xrj1wGuFj5q53M7W/sensors/23'
2018-09-03 17:54:25.919 [ERROR] [org.openhab.io.net.http.HttpUtil    ] - Fatal transport error: java.net.ConnectException: Verbindungsaufbau abgelehnt (Connection refused)
2018-09-03 17:54:25.924 [ERROR] [ab.binding.http.internal.HttpBinding] - No response received from 'http://192.168.1.55/api/hAhvO6BFxsmEF-Fzfa5sxrc5xrj1wGuFj5q53M7W/sensors/30'
2018-09-03 17
Edit: This Errors started at 17:54 and continued until now
Do you have the Hue binding installed? Given that something is adding a new Hue Thing to the inbox I would guess the answer is yes.
I guess I will give the System a day or so. That used to fix some Problems in the past, so you never know….
Thanks so far!
No Progress. Had some issues today and after a reboot it came up with the following ā€œbroken pipeā€ stuff again
##         Uptime = 0 day(s). 0:0:26
##      CPU Usage = 87.06 % avg over 4 cpu(s)  (4 core(s) x 1 socket(s))
##       CPU Load = 1m: 2.06, 5m: 0.50, 15m: 0.17
##         Memory = Free: 0.50GB (52%), Used: 0.45GB (48%), Total: 0.95GB
##           Root = Free: 11.49GB (82%), Used: 2.41GB (18%), Total: 14.53GB
##      Processes = 115 running processes of 32768 maximum processes
              /_/
[17:23:51] openhabian@openhabianpi:~$ tail -f /var/log/openhab2/openhab.log
2018-09-07 17:23:54.821 [INFO ] [egram.internal.TelegramActionService] - Bot bot1 loaded from config file
2018-09-07 17:24:04.988 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Berlin'.
2018-09-07 17:24:05.000 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '48.50238660,8.99628090'.
2018-09-07 17:24:05.011 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'de_DE'.
2018-09-07 17:24:07.102 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.50:8080
2018-09-07 17:24:07.116 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.50:8443
2018-09-07 17:24:08.187 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = f1b6f10e-e180-4de8-a9fb-b280749cfd85, base URL = http://localhost:8080)
2018-09-07 17:24:19.390 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'windows_and_doors.items'
2018-09-07 17:24:19.681 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'shutter.items'
2018-09-07 17:24:19.991 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'light_and_power.items'
2018-09-07 17:24:20.547 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'measurement.items'
2018-09-07 17:24:20.933 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'heating.items'
2018-09-07 17:24:21.055 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.items'
2018-09-07 17:24:21.380 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'weather.items'
2018-09-07 17:24:22.069 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'status.items'
2018-09-07 17:24:22.888 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2018-09-07 17:24:22.924 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
2018-09-07 17:24:32.339 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'windows_telegram.rules'
2018-09-07 17:24:34.105 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'lighting.rules'
2018-09-07 17:24:40.063 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'scenes.rules'
2018-09-07 17:24:41.195 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'automation.rules'
2018-09-07 17:24:42.095 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'shutters_telegram.rules'
2018-09-07 17:24:43.119 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-09-07 17:24:43.858 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'zuhause.sitemap'
2018-09-07 17:24:45.623 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'astro:sun:local' to inbox.
2018-09-07 17:24:45.641 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'astro:moon:local' to inbox.
2018-09-07 17:24:46.472 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:local
2018-09-07 17:24:46.543 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:sun:local every 300 seconds
2018-09-07 17:24:46.823 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:local
2018-09-07 17:24:46.825 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:local
2018-09-07 17:24:46.874 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:moon:local every 300 seconds
2018-09-07 17:24:46.943 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:sun:local every 300 seconds
2018-09-07 17:24:47.130 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:local
2018-09-07 17:24:47.168 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:moon:local every 300 seconds
2018-09-07 17:24:50.160 [INFO ] [nx.internal.connection.KNXConnection] - Established connection to KNX bus on 224.0.23.12:3671 in mode ROUTER.
2018-09-07 17:24:50.209 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2018-09-07 17:24:50.231 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mybroker'
2018-09-07 17:24:51.916 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-09-07 17:24:52.098 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-09-07 17:24:52.256 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2018-09-07 17:24:52.366 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-09-07 17:24:53.348 [INFO ] [eather.internal.common.WeatherConfig] - ProviderConfig[providerName=WUNDERGROUND,apiKey=fe5d76ac15823106]
2018-09-07 17:24:53.362 [INFO ] [eather.internal.common.WeatherConfig] - LocationConfig[providerName=WUNDERGROUND,language=de,updateInterval=30,latitude=48.51876,longitude=9.06814,woeid=<null>,locationId=home,name=Tuebingen]
2018-09-07 17:24:56.412 [INFO ] [ternal.scheduler.WeatherJobScheduler] - Starting and scheduling weatherJob-home with interval of 30 minutes
2018-09-07 17:25:01.952 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2018-09-07 17:25:01.978 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2018-09-07 17:25:02.007 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2018-09-07 17:25:02.035 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2018-09-07 17:25:02.038 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2018-09-07 17:25:05.147 [WARN ] [ve.internal.protocol.ZWaveController] - TODO: Implement processing of Request Message = -- (0x0A)
2018-09-07 17:25:05.316 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2018-09-07 17:25:05.318 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
2018-09-07 17:25:05.321 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2018-09-07 17:25:05.323 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2018-09-07 17:25:05.325 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2018-09-07 17:25:05.328 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 2
2018-09-07 17:25:05.330 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2018-09-07 17:27:11.152 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
        at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:491) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
        ... 46 more
        ... 46 more
After These two lines:
It sat just there for a Minute or two where I did Nothing, before it continued with the Errors. Stil no idea why and which pipe Brakes…
Start removing bindings one at a time until the error goes away. Once it does go away then we can start to diagnose the source of the problem.
I don’t have near enough information to provide an educated guess, but my WAG would be that the Hue bridge is dropping its connections.
As it seems to be the only one that uses a HTTP-based API I am tempted to agree with you :slight_smile:
Ok, so I’ll give it a try over the weekend
So after installing OH2 as VM on my NAS, running Ubuntu LTS, this behavior still occurs. I am back to using the HTTP binding as well as the Hue binding, as removing them didn’t change anything. So for the time being, I am living with these errors. Seems everything is still working, despite the errors. Maybe this is going to be fixed by accident in a later OH2 release :slight_smile:
Thanks a lot
I’ve been getting these error messages a lot too lately - my guess is that it’s caused by the ā€˜OpenHAB Beta’ client I use on my Android phone. Are you using the ā€˜OpenHAB’ client app too on your phone?
I was hoping to solve this issue as well - or at least stop them from getting logged but I still haven’t found the correct config line for the org.ops4j.pax.logging.cfg file…
use the OH2 console and:
log:set FATAL org.glassfish.jersey.server
It will update your org.ops4j.pax.logging.cfg file
Thanks for your fast and helpful reply!
Apparently in 2.4.0M6 the ā€˜FATAL’ enum is not recognized so I decided to try ā€˜OFF’ instead. I would have preferred to have ā€˜some’ logging available, but apparently there is nothing below log level ā€˜ERROR’.
openhab> log:set FATAL org.glassfish.jersey.server
Error executing command: No enum constant org.apache.karaf.log.core.Level.FATAL
My org.ops4j.pax.logging.cfg config is now updated to show:
log4j2.logger.org_glassfish_jersey_server.level = OFF
log4j2.logger.org_glassfish_jersey_server.name = org.glassfish.jersey.server
Any thoughts?
oops… I have to check this.
I think that Karaf used to have FATAL as a default log level but it seems that I was wrong…
time to update the docs :slight_smile:
edit: strange… Apache says that log4j2 has FATAL as a default builtin: https://logging.apache.org/log4j/2.x/manual/customloglevels.html…
Most likely the Karaf implementation of log4j2 is a bit different than the ā€œstandardā€ log4j2
