marc1310
(marc schlüter)
March 25, 2021, 11:18am
1
i make a json request and write it in a variable
var Number hours = transform("JSONPATH", "$.result.time['hours']", json_time)
in the variable hours stand now a Number, for example 1.
now i try to math the hours with 3600 in a postupdate command
json_currenttime.postUpdate(hours *3600)
but i always get a error, whats the right way to do the math?
thank you
markymark
(Mark Baumann)
March 25, 2021, 11:38am
2
There are many topics to this issue.
for example: Simple rule math help - #5 by watou or Working with maths - #2 by rlkoshak
You have explicit cast it as number.
marc1310
(marc schlüter)
March 25, 2021, 11:54am
3
Yeah i tried this but i cant use
.state as a Number, because its nö item. Its a var.
I dont know how to use it.
Have you Perhaps a example?
rossko57
(Rossko57)
March 25, 2021, 12:07pm
4
No. Transforms always return strings. “Parse” is the relevant process of reading a string into a number.
There are many hundreds of examples in this forum
rule "Energy received"
Item Energy_received_message changed
var Number Pplus_ = 5.0
var Number Pminus_ = 1.0
var Number Pdiff_ = Pplus_ - Pminus_
logInfo('rule', curstate.toString)
val String json = (Energy_received_message.state as StringType).toString
logInfo('rule', json)
var Number Pplus = Float::parseFloat(transform("JSONPATH", "$.Pplus", json))
logInfo('rule Pplus', Pplus.toString)
var Number Pminus = Float::parseFloat(transform("JSONPATH"…
Send it as string:
json_currenttime.postUpdate((hours *3600).toString)
rossko57
(Rossko57)
March 25, 2021, 12:10pm
6
The point is that if variable hours
is a string (it is) then you cannot multiply it by 3600.
marc1310:
thank you
True, missed that!
So, the correct answer is that he has to parseInt, or parseFloat the transformation.
rossko57
(Rossko57)
March 25, 2021, 6:09pm
9
Would you like to post your working version, for the benefit of later readers?
marc1310
(marc schlüter)
March 25, 2021, 8:48pm
10
of course.
var Number hours = Float::parseFloat(transform("JSONPATH", "$.result.time['hours']", json_time))
var Number minutes = Float::parseFloat(transform("JSONPATH", "$.result.time['minutes']", json_time))
var Number seconds = Float::parseFloat(transform("JSONPATH", "$.result.time['seconds']", json_time))
json_currenttime.postUpdate(hours *3600 + minutes *60 + seconds)
