- Platform information:
- Hardware: CPUArchitecture/RAM/storage
- OS: what OS is used and which version
- Java Runtime Environment: which java platform is used and what version
- openHAB version:
############### openhab #####################################################
## Ip = 192.168.XXX.YYY
## Release = Raspbian GNU/Linux 10 (buster)
## Kernel = Linux 5.4.51-v7l+
## Platform = Raspberry Pi 4 Model B Rev 1.2
## Uptime = 1 day(s). 1:13:15
## CPU Usage = 0.25% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
## CPU Load = 1m: 0.12, 5m: 0.11, 15m: 0.09
## Memory = Free: 0.30GB (8%), Used: 3.47GB (92%), Total: 3.78GB
## Swap = Free: 2.58GB (100%), Used: 0.00GB (0%), Total: 2.58GB
## Root = Free: 4.40GB (32%), Used: 9.31GB (68%), Total: 14.32GB
## Updates = 0 apt updates available.
## Sessions = 0 session(s)
## Processes = 134 running processes of 32768 maximum processes
icalendar-binding 2.5.8. and 2.5.9.202009171220 installed
configuration:
URL for calendar:
https://192.168.XXX.XXX/remote.php/dav/calendars/openhab/pinneberg_shared_by_XXXXX/
user:openhab
password:passwd
Calendar used is nextcloud
I copied the certificate to openhab and installed it to the ca-certificates using
sudo update-ca-certificates
I also installed it in the keystore using
keytool -importcert -file nextcloud.crt -keystore keystore -alias “XXXXXXXX”
restarted openhab
sudo systemctl restart openhab2
Switched the debug mode for the binding in karaf:
log:set DEBUG org.openhab.binding.icalendar
and get following error messages:
2020-09-17 17:40:54.020 [WARN ] [g.icalendar.internal.handler.PullJob] - Response for calendar request could not be retrieved. Error message is: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
2020-09-17 17:42:54.086 [WARN ] [g.icalendar.internal.handler.PullJob] - Response for calendar request could not be retrieved. Error message is: java.io.EOFException: HttpConnectionOverHTTP@1c2e57a::DecryptedEndPoint@8772d8{/192.168.XXX.XXX:443<->/192.168.XXX.YYY:49468,CLOSED,fill=-,flush=C,to=1/0}
the calendar stays offline, since the binding is not downloading calendar entries.
I am lost
Thanks for help
Georg
