When I use a icalendar eventfilter I like to use this REGEX
/Holiday|no precondition/i
How can I implement this? The normal “Holiday|no precondition” works but it is case sensitive…
Andy
Andy
yes it says in the docs but it isn’t, that is why I ask if I have to “activate” it somehow.
Well I’d consider that a defect you should log.
But did you try your suggested expression? Or any other?
So do you mean this expression
I couldn’t test since it gave me an error and I think it is not supported that way
Based on the way Java does case insensitive, I’d try (?i)Holiday|no precondition
thx a lot seems to work this way
