I use the iCalendar add-on for multiple events throughout the day. However, I’ve discovered that for the events right after a daylight savings time change (EDT/EST, in my case), the times of the events do not reflect the change in daylight savings, so events trigger either 1 hour early or late. It took four events to execute before it fixed itself.
Is there a setting that needs to change in the binding or should I put in a bug report?
