Icloud exception error
The iclud binding has been working great for months and then suddenly with no changes around 24 hr ago I started seeing these errors in the log, can some one advise what might be wrong.
2018-07-25 19:44:09.603 [WARN ] [d.handler.ICloudAccountBridgeHandler] - Unable to refresh device data
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
	at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) ~[?:?]
	at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1964) ~[?:?]
	at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:328) ~[?:?]
	at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:322) ~[?:?]
	at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1614) ~[?:?]
	at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:216) ~[?:?]
	at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1052) ~[?:?]
	at sun.security.ssl.Handshaker.process_record(Handshaker.java:987) ~[?:?]
	at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1072) ~[?:?]
	at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1385) ~[?:?]
	at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1413) ~[?:?]
	at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1397) ~[?:?]
	at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559) ~[?:?]
	at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185) ~[?:?]
	at sun.net.www.protocol.http.HttpURLConnection.getOutputStream0(HttpURLConnection.java:1334) ~[?:?]
	at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(HttpURLConnection.java:1309) ~[?:?]
	at sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(HttpsURLConnectionImpl.java:259) ~[?:?]
	at org.openhab.binding.icloud.internal.Connection.postRequest(Connection.java:95) ~[?:?]
	at org.openhab.binding.icloud.internal.Connection.requestDeviceStatusJSON(Connection.java:55) ~[?:?]
	at org.openhab.binding.icloud.handler.ICloudAccountBridgeHandler.lambda$0(ICloudAccountBridgeHandler.java:81) ~[?:?]
	at org.eclipse.smarthome.core.cache.ExpiringCache.refreshValue(ExpiringCache.java:81) ~[?:?]
	at org.eclipse.smarthome.core.cache.ExpiringCache.getValue(ExpiringCache.java:61) ~[?:?]
	at org.openhab.binding.icloud.handler.ICloudAccountBridgeHandler.refreshData(ICloudAccountBridgeHandler.java:132) ~[?:?]
	at org.openhab.binding.icloud.handler.ICloudAccountBridgeHandler.lambda$1(ICloudAccountBridgeHandler.java:123) ~[?:?]
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
	at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:397) ~[?:?]
	at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:302) ~[?:?]
	at sun.security.validator.Validator.validate(Validator.java:262) ~[?:?]
	at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324) ~[?:?]
	at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229) ~[?:?]
	at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124) ~[?:?]
	at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1596) ~[?:?]
	... 26 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
	at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141) ~[?:?]
	at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126) ~[?:?]
	at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280) ~[?:?]
	at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:392) ~[?:?]
	... 26 more
Paul
Same issue there
Looks like we have 3 threat around the same issue.
→ Sysinfo-Binding in OH2 - #3 by scha
Now it 4 problems, my error is "018-07-25 16:50:00.165 [WARN ] [d.handler.ICloudAccountBridgeHandler] - Unable to refresh device data
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target "
Here is my issue on that. I’m using 2.3.0 stable so it didn’t changed anything for me, just stopped working yesterday…
I have the same issue.
Shall we all move to single topic, lets pick Icloud binding - General SSLEngine problem - #2 by Chri46
