2020-01-27 21:54:46.530 [ERROR] [org.apache.felix.fileinstall ] - Failed to install artifact: /usr/share/openhab2/addons/org.openhab.binding.icloud-2.5.1.jar
org.osgi.framework.BundleException: The bundle file:/usr/share/openhab2/addons/org.openhab.binding.icloud-2.5.1.jar does not have a META-INF/MANIFEST.MF! Make sure, META-INF and MANIFEST.MF are the first 2 entries in your JAR!
Here is my version:
no test for this folder /usr/share/openhab2/addons, i move direct to /var/lib/openhab2/tmp/kar/openhab-addons-2.5.1/org/openhab/addons/bundles/org.openhab.binding.icloud/2.5.1 and install from paper ui
i edit orther file and put to /usr/share/openhab2/addons and work
259 ā Active ā 80 ā 2.5.2.202001271940 ā openHAB Add-ons :: Bundles :: iCloud Binding
Thanks! Works for me.
Good Morning @rkrisi,
thanks again. Seems working again.
Too bad Apple is changing certificates that quick atm, but glad to her you are working on an autoupdate for the certificate with @Hawkeye.
Hi will this work on 2.4?
Yes it will work
thanks all for all the effort here
I second the aboveā¦thanks for all your hard work. It must be so frustrating having something that is such a great binding break only because Apple donāt like to share their ballā¦
Happy to help with the testing of the autoupdate if / when needed.
This version is working but still has some SSL errors now and then.
I just had another error at 9 am CET:
java.util.concurrent.ExecutionException: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
I donĀ“t know what Apple is currently doing with iCloud but it drives me crazy
Thanks for you work Kristof and Erwin!
It might be that they also implementing some automation to change the key regularly, not just once/year or soā¦
However it seems that it is still running for me with the latest versionā¦
Yeah itĀ“s still running and recovers after some minutes.
The last downtimes were around 5 minutes long.
Just wanted to let you know what i can observe at my end
2020-01-29 09:08:45.268 [hingStatusInfoChangedEvent] - 'icloud:account:openHAB' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): java.util.concurrent.ExecutionException: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
2020-01-29 09:13:46.405 [hingStatusInfoChangedEvent] - 'icloud:account:openHAB' changed from OFFLINE (COMMUNICATION_ERROR): java.util.concurrent.ExecutionException: javax.net.ssl.SSLHandshakeException: General SSLEngine problem to ONLINE
2020-01-29 09:23:48.211 [hingStatusInfoChangedEvent] - 'icloud:account:openHAB' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): java.util.concurrent.ExecutionException: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
2020-01-29 09:28:49.428 [hingStatusInfoChangedEvent] - 'icloud:account:openHAB' changed from OFFLINE (COMMUNICATION_ERROR): java.util.concurrent.ExecutionException: javax.net.ssl.SSLHandshakeException: General SSLEngine problem to ONLINE
I just tested it with @rkrisi and the following snapshot seems to be working:
would be great if more people can try out this snapshot-build to see if it works, and report back any issues. This snapshot doesnāt contain a certificate file anymore, instead it dynamically retrieves & updates it as needed.
One thing we noted was that I seem to be getting a different certificate on my machine than @rkrisi is, so it would be good to get more people to test it.
Any feedback is appreciated!
Update: this has been removed for security reasons
For others: this is what I said I wanted to, but @Hawkeye was faster than me, so enjoy his work!
It works as it should for me. Certs shouldnāt be an issue anymoreā¦
I have installed this and for me it seems to be working fine.
Many thanks for the work on this.
Hi I have been running with the snapshot for some time (multiple days) and I am still getting issues, here are logged some errors from today.
LOG
2020-01-30 16:31:50.555 [WARN ] [l.handler.ICloudAccountBridgeHandler] - Unable to refresh device data
java.io.IOException: java.util.concurrent.ExecutionException: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:259) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrl(HttpUtil.java:156) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrl(HttpUtil.java:131) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpRequestBuilder.getContentAsString(HttpRequestBuilder.java:135) ~[?:?]
at org.openhab.binding.icloud.internal.ICloudConnection.callApi(ICloudConnection.java:91) ~[?:?]
at org.openhab.binding.icloud.internal.ICloudConnection.requestDeviceStatusJSON(ICloudConnection.java:72) ~[?:?]
at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.lambda$0(ICloudAccountBridgeHandler.java:95) ~[?:?]
at org.eclipse.smarthome.core.cache.ExpiringCache.refreshValue(ExpiringCache.java:101) ~[?:?]
at org.eclipse.smarthome.core.cache.ExpiringCache.getValue(ExpiringCache.java:72) ~[?:?]
at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.refreshData(ICloudAccountBridgeHandler.java:152) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_201]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_201]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_201]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_201]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_201]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_201]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_201]
Caused by: java.util.concurrent.ExecutionException: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[?:?]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[?:?]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:685) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:250) ~[?:?]
... 16 more
Caused by: javax.net.ssl.SSLHandshakeException: General SSLEngine problem
at sun.security.ssl.Handshaker.checkThrown(Handshaker.java:1521) ~[?:1.8.0_201]
at sun.security.ssl.SSLEngineImpl.checkTaskThrown(SSLEngineImpl.java:528) ~[?:1.8.0_201]
at sun.security.ssl.SSLEngineImpl.writeAppRecord(SSLEngineImpl.java:1197) ~[?:1.8.0_201]
at sun.security.ssl.SSLEngineImpl.wrap(SSLEngineImpl.java:1165) ~[?:1.8.0_201]
at javax.net.ssl.SSLEngine.wrap(SSLEngine.java:509) ~[?:1.8.0_201]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.flush(SslConnection.java:891) ~[?:?]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:422) ~[?:?]
at org.eclipse.jetty.io.WriteFlusher.completeWrite(WriteFlusher.java:378) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.lambda$fill$1(SslConnection.java:669) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) ~[?:?]
... 1 more
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) ~[?:1.8.0_201]
at sun.security.ssl.SSLEngineImpl.fatal(SSLEngineImpl.java:1709) ~[?:1.8.0_201]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:318) ~[?:1.8.0_201]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:310) ~[?:1.8.0_201]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1639) ~[?:1.8.0_201]
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:223) ~[?:1.8.0_201]
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1037) ~[?:1.8.0_201]
at sun.security.ssl.Handshaker$1.run(Handshaker.java:970) ~[?:1.8.0_201]
at sun.security.ssl.Handshaker$1.run(Handshaker.java:967) ~[?:1.8.0_201]
at java.security.AccessController.doPrivileged(Native Method) ~[?:1.8.0_201]
at sun.security.ssl.Handshaker$DelegatedTask.run(Handshaker.java:1459) ~[?:1.8.0_201]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.fill(SslConnection.java:526) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:128) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:73) ~[?:?]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:133) ~[?:?]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:154) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:426) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:320) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:158) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) ~[?:?]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) ~[?:?]
... 1 more
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:397) ~[?:1.8.0_201]
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:302) ~[?:1.8.0_201]
at sun.security.validator.Validator.validate(Validator.java:262) ~[?:1.8.0_201]
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324) ~[?:1.8.0_201]
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:281) ~[?:1.8.0_201]
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:136) ~[?:1.8.0_201]
at org.eclipse.smarthome.io.net.http.internal.ExtensibleTrustManagerImpl.checkServerTrusted(ExtensibleTrustManagerImpl.java:121) ~[?:?]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1626) ~[?:1.8.0_201]
... 1 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141) ~[?:1.8.0_201]
at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126) ~[?:1.8.0_201]
at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280) ~[?:1.8.0_201]
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:392) ~[?:1.8.0_201]
... 1 more
here is the only icloud bundle listed
277 ā Active ā 80 ā 2.5.2.202001211144 ā openHAB Add-ons :: Bundles :: iCloud Binding
Paul
Looks good with your latest snapshot, I restarted openhab and this message appeared.
[WARN ] [l.handler.ICloudAccountBridgeHandler] - SSL exception during handshake, attempting to refresh certificate automatically
Thanks for you work.
@HaKuNa Thatās the new functionality kicking in, it should be able to keep the binding working without downtime, as long as a new certificate is available from the server. In any case it will do itās best to recover or else it will keep trying.
@idkpmiller try my latest snapshot, it should be the last time you update the binding for this problem
I created a PR https://github.com/openhab/openhab-addons/pull/6937
Anybody checking it out that is able & authorised to review it would be greatly appreciated, would be good to get into the next release.
Just installed this latest snapshot build.
How to check the certificate?
