i´ve a problem with one of my icons. It´s the humidity.png. It´s correctly displayed at the sitemap.
Now i want that the icon is changing when the humidity goes up or down. So i´ve created the icons humidity-0.png, humidity-10.png and so on, like the rollershutter icons.
I use the weather binding with this line:
Number Luftfeuchtigkeit “Luftfeuchtigkeit [%d %%]” {weather=“locationId=home, type=atmosphere, property=humidity”}
At the moment the humidity is at 71%…so icon humidity-70.png should be displayed…but it didn´t. It shows me the humidity.png.
Edit: The device shows 99% Battery status (LG G4) but MQTT has updated a few minutes ago,
therefore openhab displays 90%.
Battery usage is only accurate when i move the device (if the GPS Location changes frequently)
Okay,
First of all, you need to create a second item.
In my example mqttPowU2 is the “raw” input from the sensor. mqttPowIconU2 is the icon-number-item (States: 0,25,50,75,100)
Could be easily adjusted to your needs (10% Steps)
rule "BatteryIcon GT S2"
Item mqttPowU2 received update
if (mqttPowU2.state>=0 && mqttPowU2.state<15) {
postUpdate(mqttPowIconU2, 0)
if (mqttPowU2.state>=15 && mqttPowU2.state<35) {
postUpdate(mqttPowIconU2, 25)
if (mqttPowU2.state>=35 && mqttPowU2.state<60) {
postUpdate(mqttPowIconU2, 50)
if (mqttPowU2.state>=60 && mqttPowU2.state<80) {
postUpdate(mqttPowIconU2, 75)
if (mqttPowU2.state>=80 && mqttPowU2.state<=100) {
postUpdate(mqttPowIconU2, 100)
Add this to your sitemap (Yes, each state is another line in the sitemap file )
Text item=mqttPowU2 icon="measure_battery-0" label="GT S2 via MQTT [%d %%]" visibility=[mqttPowIconU2==0] Text item=mqttPowU2 icon="measure_battery-25" label="GT S2 via MQTT [%d %%]" visibility=[mqttPowIconU2==25] Text item=mqttPowU2 icon="measure_battery-50" label="GT S2 via MQTT [%d %%]" visibility=[mqttPowIconU2==50] Text item=mqttPowU2 icon="measure_battery-75" label="GT S2 via MQTT [%d %%]" visibility=[mqttPowIconU2==75] Text item=mqttPowU2 icon="measure_battery-100" label="GT S2 via MQTT [%d %%]" visibility=[mqttPowIconU2==100]
