I’m running openHAB 3.0 on docker under an Ubuntu host system.
I’ve noticed that the in the special pages (location, devices and properties) the icon states not always reflect the state of the corresponding item.
I have two items connected via Homematic binding. The first item is a simple door contact, the second item is a window rotary handle sensor. Whereas the first item does reflect the correct item state (OPEN, CLOSED) using the frontdoor icon, the second item always shows a closed window icon for the states OPEN, Closed and Tilted.
If I use the same item in a sitemap, both icons reflect the corresponding state correctly.
Is this by design?
