I made some frames for the different rooms, one of them with some temperature control.
When pressing “More” it goes into this. Turning between On, Off and Auto works fine, and setting the temperature too. But the “Mode” icon only changes when I am in the “More” section. On the sitemap main page it does not update when the different modes are selected.
Do I need to do something different to make it update on the main page too? If I change mode, and then refreshes the page, the icon has changed, but I have to manually refresh the page every time. Except when inside the “More” section.
Frame label="Workroom"
Switch item=electrodragon1gp13 label="Over monitor light"
Switch item=workroomTempControl mappings=[100="On", 20="Off", 65="Auto"]
Text label="More" icon="garage"
Text item=smartSocket4 label="Heater" visibility=[workroomTempControl=="100", workroomTempControl=="65"]
Text item=workroomTempTarget visibility=[workroomTempControl=="65"]
Switch item=workroomTempChanger mappings=[1="Up", 0="Down"] visibility=[workroomTempControl=="65"]
Text item=espeasyNodeMCU09temp
Text item=espeasyNodeMCU09humi
