After the IDE is configured and the code repositories are cloned, the build mostly succeeds but several projects fail to build. Running “Perform Setup Tasks…” and doing a full clean/rebuild didn’t solve the problems. I see a reference to mysterious build problems in the instructions. Is it expected that there are several hundred build errors (about 10 projects)?
I am able to launch openHAB2 and it appears to start successfully with the default plugins. However, I see one error like the following:
Where is the current openHAB continuous integration server? Assuming those builds are succeeding, I’d like to understand what’s happening with my build. Thanks.
Thanks. I wasn’t sure about cloudbees since I had seen references to Travis CI while googling. So these errors are just related to the Eclipse workspace configuration?
