hello,
on a sitemap I want to implement an action event that the user can “fire” but the item should no change its state. Currently I am using a switch, always setting it to off once the user has switched it on. Is there a more elegant way to do that?
Thank you
Do you use a regular switch?
With a sitemap switch and some mappings you can achieve this:
Switch item=myItem label="My-Label" icon="time" mappings=[120="2min", 300="5 min"]
In my case the Item is a number item which then gets a command and is set back to zero at some point.
zero
For a short amount of time it is visibly changed of course:
Nut sure if this is at least a bit “more elegant” for you. I am using the visible change on purpose as a response for a succesful command.
cool, thanks. That is what I looked for.
