By the way, I don’t see DEBUG entries in the openhab.log.
I switched this on for zwave as well (which should send a lot of DEBUG messages), but I don’t see them either.
post your $OPENHAB_USERDATA/etc/org.ops4j.pax.logging.cfg
just to double check it
free space (df -h
) on the rPi3 is enough… correct ?
Did you ever analyze the generated heapdump file? With this option it generates a copy of the Java memory to a file when it runs out of memory. So you can analyze what is the root cause and if there is a memory leak.
See also:
How to find the cause of a OutOfMemoryError in OH2?
Ahhh I see you did in How to find the cause of a OutOfMemoryError in OH2? - #27 by NCO . Looks like it is caused by the sitemap events.
brings:
[15:10:21] openhabian@Homer:~$ df -h
Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf
/dev/root 30G 8,5G 20G 31% /
devtmpfs 481M 0 481M 0% /dev
tmpfs 486M 32K 486M 1% /dev/shm
tmpfs 486M 50M 437M 11% /run
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 486M 0 486M 0% /sys/fs/cgroup
/dev/sda1 41M 21M 20M 52% /boot
192.168.178.39:/volume1/openhab/backup 2,7T 1,8T 903G 68% /mnt/nfs/openhab/backup
contains:
log4j2.logger.amazon\ echo\ control\ binding.level = DEBUG
log4j2.logger.amazon\ echo\ control\ binding.name = Amazon Echo Control Binding
log4j2.logger.zwave\ binding.level = DEBUG
log4j2.logger.zwave\ binding.name = ZWave Binding
I used this in the beginning and had a look into it with Mem-Analyzer, but must admit that I had difficulties to interpret it.
After I increased the memory, I though I have solved the issue, but then it popped up again.
try replacing the delimiter from \
to _
and the name is something like: org.openhab.xyz
log4j2.logger.amazon_echo_control_binding.level = DEBUG
log4j2.logger.amazon_echo_control_binding.name = <org.openhab.xyz>
log4j2.logger.zwave_binding.level = DEBUG
log4j2.logger.zwave_binding.name = org.openhab.binding.zwave
alright.
I will delete the lines and set it new from karaf with the “real” jar-file name.
Thank you!
EDIT:
That’s better.
Now I see the DEBUG entries and will wait for the heap space error…
Ooops - it did it again…
Regular restart:
2018-11-17 19:14:21.134 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2018-11-17 19:14:21.755 [INFO ] [arthome.model.script.moverules.rules] - system started triggered
2018-11-17 19:14:21.764 [INFO ] [arthome.model.script.moverules.rules] - timer already existing
2018-11-17 19:14:21.777 [INFO ] [marthome.model.script.startup.rules:] - --------> System / Config reloaded <--------.
2018-11-17 19:41:00.090 [DEBUG] [control.internal.WebSocketConnection] - Send Ping
2018-11-17 19:41:00.112 [DEBUG] [control.internal.WebSocketConnection] - Send message with length 98
2018-11-17 19:41:00.228 [DEBUG] [control.internal.WebSocketConnection] - Pong received
2018-11-17 19:43:24.098 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@d3076c' takes more than 5000ms.
2018-11-17 19:44:00.254 [DEBUG] [control.internal.WebSocketConnection] - Send Ping
2018-11-17 19:44:00.380 [DEBUG] [control.internal.WebSocketConnection] - Send message with length 98
2018-11-17 19:44:00.488 [DEBUG] [control.internal.WebSocketConnection] - Pong received
2018-11-17 19:44:19.045 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.events.internal.EventBridge@1bef69' takes more than 5000ms.
2018-11-17 19:44:37.310 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@d3076c' takes more than 5000ms.
2018-11-17 19:45:48.218 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@d3076c' takes more than 5000ms.
2018-11-17 19:46:06.017 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'EventSubscriber.receive()' on 'org.eclipse.smarthome.core.internal.items.ItemUpdater@d3076c': Java heap space
java.lang.OutOfMemoryError: Java heap space
at java.util.Arrays.copyOf(Arrays.java:3332) ~[?:?]
at java.lang.AbstractStringBuilder.ensureCapacityInternal(AbstractStringBuilder.java:124) ~[?:?]
at java.lang.AbstractStringBuilder.append(AbstractStringBuilder.java:448) ~[?:?]
at java.lang.StringBuffer.append(StringBuffer.java:270) ~[?:?]
at java.io.StringWriter.write(StringWriter.java:112) ~[?:?]
at com.google.gson.stream.JsonWriter.string(JsonWriter.java:585) ~[?:?]
at com.google.gson.stream.JsonWriter.value(JsonWriter.java:419) ~[?:?]
at com.google.gson.internal.bind.TypeAdapters$16.write(TypeAdapters.java:422) ~[?:?]
at com.google.gson.internal.bind.TypeAdapters$16.write(TypeAdapters.java:406) ~[?:?]
at com.google.gson.internal.bind.TypeAdapterRuntimeTypeWrapper.write(TypeAdapterRuntimeTypeWrapper.java:69) ~[?:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$1.write(ReflectiveTypeAdapterFactory.java:125) ~[?:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.write(ReflectiveTypeAdapterFactory.java:243) ~[?:?]
at com.google.gson.Gson.toJson(Gson.java:669) ~[?:?]
at com.google.gson.Gson.toJson(Gson.java:648) ~[?:?]
at com.google.gson.Gson.toJson(Gson.java:603) ~[?:?]
at com.google.gson.Gson.toJson(Gson.java:583) ~[?:?]
at org.eclipse.smarthome.core.events.AbstractEventFactory.serializePayload(AbstractEventFactory.java:85) ~[?:?]
at org.eclipse.smarthome.core.items.events.ItemEventFactory.createStateChangedEvent(ItemEventFactory.java:304) ~[?:?]
at org.eclipse.smarthome.core.items.GenericItem.sendStateChangedEvent(GenericItem.java:231) ~[?:?]
at org.eclipse.smarthome.core.items.GenericItem.applyState(GenericItem.java:225) ~[?:?]
at org.eclipse.smarthome.core.items.GenericItem.setState(GenericItem.java:209) ~[?:?]
at org.eclipse.smarthome.core.library.items.ImageItem.setState(ImageItem.java:64) ~[?:?]
at org.eclipse.smarthome.core.internal.items.ItemUpdater.receiveUpdate(ItemUpdater.java:78) ~[?:?]
at org.eclipse.smarthome.core.items.events.AbstractItemEventSubscriber.receive(AbstractItemEventSubscriber.java:50) ~[?:?]
at sun.reflect.GeneratedMethodAccessor20.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:?]
2018-11-17 19:46:43.096 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@14ad210' takes more than 5000ms.
2018-11-17 19:46:18.868 [ERROR] [me.core.internal.events.EventHandler] - Dispatching/filtering event for subscriber 'org.eclipse.smarthome.core.events.EventSubscriber' failed: Java heap space
I don’t see a direct link to amazonechocontrol though…
this does not work:
Could not parse line 'pid:org.openhab.mqtt'
do you mean:
mosquitto.pid=org.openhab.mqtt
is it the first line in your /etc/openhab2/services/mqtt.cfg
it should look like:
there are just some comments above, but nothing else.
Does this make a dfference?
absolutely
It has to be the very first line in that file for it to work
no error anymore - thanks
EDIT:
To be more precise: I don’t get the following error an more:
the original problem (heap space related to amazon echo binding or actually synolog surveillance station still persists)
by the way - can I use both?
The option above to dump the OOM and the expanded memory?
like this?
EXTRA_JAVA_OPTS="-XX:+HeapDumpOnOutOfMemoryError -Xms400m -Xmx650m"
Thanks for all teh tips in this thread.
If it is to any help I also got java heap problems:
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2018-12-11 17:17:10 CET; 1 day 7h ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Main PID: 538 (java)
CGroup: /system.slice/openhab2.service
└─538 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib
Dec 13 00:15:03 openHABianPi karaf[538]: at jdk.nashorn.api.scripting.NashornScriptEngine.<init>(NashornScriptEngine.java:143)
Dec 13 00:15:03 openHABianPi karaf[538]: at jdk.nashorn.api.scripting.NashornScriptEngineFactory.getScriptEngine(NashornScriptEngineFactory.java:148)
Dec 13 00:15:03 openHABianPi karaf[538]: at javax.script.ScriptEngineManager.getEngineByName(ScriptEngineManager.java:238)
Dec 13 00:15:03 openHABianPi karaf[538]: at org.eclipse.smarthome.transform.javascript.internal.JavaScriptTransformationService.transform(JavaScriptTransformati
Dec 13 00:15:03 openHABianPi karaf[538]: at org.openhab.core.transform.TransformationHelper$TransformationServiceDelegate.transform(TransformationHelper.java:65
Dec 13 00:15:03 openHABianPi karaf[538]: at org.openhab.binding.http.internal.HttpBinding.execute(HttpBinding.java:194)
Dec 13 00:15:03 openHABianPi karaf[538]: at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:144)
Dec 13 00:15:03 openHABianPi karaf[538]: at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:166)
Dec 13 00:15:03 openHABianPi karaf[538]: Caused by: java.lang.OutOfMemoryError: Java heap space
Dec 13 00:15:03 openHABianPi karaf[538]: java.lang.OutOfMemoryError: Java heap space
I also think its either amazon echo binding or the http binding pulling my hue motion sensor every 1s
logfile look like this:
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.3.21.v20170918]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [76:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [76:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [76:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [87:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [87:org.eclipse.jetty.util:9.3.21.v20170918]
Caused by: org.glassfish.jersey.server.ContainerException: java.lang.OutOfMemoryError: Java heap space
at org.glassfish.jersey.servlet.internal.ResponseWriter.rethrow(ResponseWriter.java:278) ~[?:?]
at org.glassfish.jersey.servlet.internal.ResponseWriter.failure(ResponseWriter.java:260) ~[?:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:509) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:334) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
... 31 more
2018-12-12 23:57:44.110 [WARN ] [eclipse.jetty.servlet.ServletHandler] -
javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.OutOfMemoryError: Java heap space
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
... 31 more
2018-12-12 23:56:31.528 [ERROR] [ersey.server.ServerRuntime$Responder] - Error while committing the output stream.
java.io.IOException: java.lang.IllegalArgumentException: Self-suppression not permitted
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:229) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpOutput.flush(HttpOutput.java:355) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.glassfish.jersey.servlet.internal.ResponseWriter$NonCloseableOutputStreamWrapper.flush(ResponseWriter.java:330) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.message.internal.CommittingOutputStream.flush(CommittingOutputStream.java:292) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.message.internal.OutboundMessageContext.commitStream(OutboundMessageContext.java:817) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ContainerResponse.commitStream(ContainerResponse.java:394) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:752) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [170:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
Caused by: java.lang.IllegalArgumentException: Self-suppression not permitted
at java.lang.Throwable.addSuppressed(Throwable.java:1043) ~[?:?]
at org.eclipse.jetty.server.HttpOutput.$closeResource(HttpOutput.java:221) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:221) ~[84:org.eclipse.jetty.server:9.3.21.v20170918]
... 49 more
2018-12-12 23:57:19.799 [WARN ] [eclipse.jetty.servlet.ServletHandler] -
... 31 more
2018-12-13 00:59:50.953 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '60.3409602,5.355955799999999'.
2018-12-13 00:59:56.322 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = a0a28f98-207b-4d34-b5eb-95f8fcac94bd, base URL = http://localhost:8080)
2018-12-13 01:00:05.278 [WARN ] [eclipse.jetty.servlet.ServletHandler] -
javax.servlet.ServletException: java.lang.IllegalStateException: Request scope has been already shut down.
Caused by: java.lang.IllegalStateException: Request scope has been already shut down.
at jersey.repackaged.com.google.common.base.Preconditions.checkState(Preconditions.java:173) ~[165:org.glassfish.jersey.bundles.repackaged.jersey-guava:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.retrieveCurrent(RequestScope.java:239) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:314) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2]
... 31 more
Logging won’t help with these out of memory issues. It will always be just another thread that runs into the memory limits. Only heapdumps allow for inspecting what is consuming all the memory.
See also How to find the cause of a OutOfMemoryError in OH2?
@NCO did you get it to work?
@mstormi whats the differnce between the above from NCO and yours -Xmx600m, which one to use or both?
So I did start from scratch again with a brand new RPI3b+ and I have only installed mqtt inbuilt , netatmo and GPIO binding, 1 sitemap, 200 items and no rules, and it crashed yesterday due to java heap memory. So why is this an issue? Could it be the Netatmo binding because thats the only binding @NCO and me have in common. Because I dont see any other here on the forum having these issues, and I never heard of anyone with home Assistant having problem with this.
I have changed hardware, fresh install with few items and problem still occurs, so I am unsure what to do next to get rid of the problem, because a crash every week is to often…
Well some 50MB. You can also use a way larger figure here so you get hit later. But use -Xmx just once.
Only proper solution is to find the component that has memory leaks. Try running with the Netatmo binding for some time and observe memory consumption.
thanks @mstormi, so I do :
sudo nano /etc/default/openhab2
and change to this
but how do I observe memory consumption?
sudo java -XX:+PrintFlagsFinal -version | findstr HeapSize
returns
uintx ErgoHeapSizeLimit = 0 {product}
uintx HeapSizePerGCThread = 67108864 {product}
uintx InitialHeapSize := 16777216 {product}
uintx LargePageHeapSizeThreshold = 134217728 {product}
uintx MaxHeapSize := 255852544
Yes.
You can also omit the -XX… and use a larger -Xmx value just keep in mind the RPi only has 1GB so beyond that you’ll run into swapping/paging.
Use top
or ps
