Issue of the topic:
Do i need to install java or does it get installed with openhabian?
I the install doc says the prerec for openhabian is java but no information on how to install it on the SC card that I use for openhabian.
I have the opehab welcome window running but can’t get visual studio to store the config files to the openhab on my razpi.
Please post configurations (if applicable):
Items configuration related to the issue
Sitemap configuration related to the issue
Rules code related to the issue
Services configuration related to the issue
If logs where generated please post these here using code fences:
In openhab-config menu 40 => 45 it’s possible to select from a list of java packages.
You would like to write a config file to a share on the Raspi from the computer you run visual studio on ?
Is the share successfully mounted on the computer you run visual studio on ?
My intention is to edit the config files in my host Raspi 192.168.0.15.
I think my share is successfully set up. Used explorer, open access, entered 192.168.0.15, and I see the 192.168.0.15 under Network.
Also visual studio shows settings.jason: {
“openhab.host”: “192.168.0.15”
Is this correct?
I also created a drive in explorer where the 192.168.0.15 files are located by using “easy access”.
Went back to Vis Stu on explorer>start.add workspace folder; and got this error repeated twice:
[Error - 9:39:48 AM] Connection to server is erroring. Shutting down server.
It appears i can access demo configurations. I tried to bring up the Preview Map by selecting the openHab icon in the upper right-hand corner, but it brings up a blank screen when on all demo items.
server output error: [Error - 11:41:45 AM] Connection to server is erroring. Shutting down server
