diado
(jando)
December 7, 2021, 1:47am
1
Hello all,
I have a sensor that posts it value to a MQTT topic with a sub topic.
Mean topic is SCD
sub topic is temperature
Now how do i wright dis down in the following part."
if (topic == "TEST")
Wen i have
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived in topic: ");
Serial.println(topic);
Serial.print("Message:");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
if (topic == "SCD/temperature") {
Serial.println("Received"));
I do receive this in the monitor:
23:27:31.092 → Ambient = 20.47C Object = 20.05C
But its not posting “Received”
rossko57
(Rossko57)
December 7, 2021, 10:14am
2
What do you want to write in ? Is this something to do with openHAB, what version? Are you trying to write a rule, a transformation, a binding?
diado
(jando)
December 10, 2021, 7:21am
3
It is for a sensor i want to connect to openhab.
But i have it working.
String strTopic = String((char*)topic);
if (strTopic == "SCD/temperature") {
char buffer[6];
memcpy(buffer, payload, length); //copy the payload to the buffer
buffer[length] = '\0'; //terminate the string (NOT a String !
temp = String((char*)payload).toFloat();
Serial.print("Message1:");
Serial.println(temp);
if (strTopic == "SCD/humidity") {
char buffer[6];
hum = String((char*)payload).toFloat();
Serial.print("Message2:");
Serial.println(hum);
You definitely should have mentioned that you are talking about the program that runs on your microprocessor (probably ESP32 or 8266).
I do not want to be rude but that definitely belongs to another community (arduino for example), but asking in the openHAB forum how to code Arduino/C++ would be the same as asking microsoft how to code games in Unity or Unreal engine…
C++ comes also with some string functions, so instead of copying buffers which might be dangerous, you can also use
strcmp()
https://www.cplusplus.com/reference/cstring/strcmp/
system
(system)
Closed
January 21, 2022, 6:19am
7
