I have a string, and when that string get an update to the value “A” - then I would like a rule that checks if the stings get an update to value “B” - If the string does not get an update to the value “B” within 40 seconds then I would like to execute: sendCommand(Relay_Switch, “OFF”).
The problem is that I have no idea how to write such a script, can any one help me?
Fire a rule from string update.
Check to see if value is “A”, if so start (or restart) a timer.
Else
Check to see if value is “B”, if so is the timer running, if so do the task.
You’ll need to set up a global variable to hold the timer so that it is visible to different runs of the same rule.
The timer doesn’t need to do anything, except null itself on completion.
var Timer timer = null
rule "timmer string"
Item timmerstring changed to "A"
if (timer === null) {
timer = createTimer(now.plusSeconds(40), [ |
if (timerstring.state.toString != "B") {
Relay_Switch.sendCommand(OFF)
timer = null
