Hi all
I have some switch items that pick up their ON/OFF state updates from an MQTT topic driven by an RF remote. This works fine for the most part. The issue is that the “group” on/off buttons on the RF remote actually send an ALLON or ALLOFF command addressed to button 1.
To get around it, I created a dummy item that takes state updates from the MQTT topic for button1 but has a transform file that means it will only accept ALLON or ALLOFF.
This works fine and the socket1 and group/all items in Openhab do what they should but, because they both receive the ON/OFF/ALLON/ALLOFF commands, I regularly get the following in the logs:
[WARN ] [b.core.events.EventPublisherDelegate] - given new state is NULL, couldn’t post update for ‘LivingRoom_HESocket1’
[WARN ] [b.core.events.EventPublisherDelegate] - given new state is NULL, couldn’t post update for ‘LivingRoom_HESocketAll’
Not a big deal, things work fine, but it would be nice to clear this up. Is there anyway to configure a switch item to ignore certain state updates?
thanks
Dave
