Hi Community.
Did someone try the IHC binding in latest SNAPSHOT?
i get this error when trying to connect. Installation is on Raspberry Pi2
openhab> log:tail
15:26:42.443 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
15:26:42.634 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
15:26:42.957 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
15:26:43.299 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-package-standard’: Error restarting bundles
15:26:43.585 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
15:26:43.681 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-package-standard’: Error restarting bundles
15:29:19.594 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
15:29:31.316 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
15:29:31.565 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
15:29:33.647 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
15:29:33.901 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
15:29:34.078 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
15:30:32.323 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService, id=392, bundle=188/mvn:org.openhab.binding/org.openhab.binding.ihc/1.9.0-SNAPSHOT]: Unexpected problem updating configuration org.openhab.ihc
java.lang.NumberFormatException: null
at java.lang.Integer.parseInt(Integer.java:542)[:1.8.0_65]
at java.lang.Integer.parseInt(Integer.java:615)[:1.8.0_65]
at org.openhab.binding.ihc.internal.IhcBinding.updated(IhcBinding.java:344)[188:org.openhab.binding.ihc:1.9.0.201607260110]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.ConfigurationManager$UpdateConfiguration.run(ConfigurationManager.java:1753)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:143)[7:org.apache.felix.configadmin:1.8.8]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:110)[7:org.apache.felix.configadmin:1.8.8]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
