I have two IHC controllers running. I would like to connect both to the same Openhab installation.
Is this possible?
Is this possible?
Multiple controllers are not currently supported, but you can add another “slave” openhab instance which only have ihc binding and all items related to this controller. Then use e.g. mqtt event bus binding to link slave openhab to you main openhab instance.
Hi Pauli,
Thanks for idea. I will go in that direction instead of customizing the current binding.
