Hey.
I have made an items file and a things file to my IHC controller. The binding finds my in / outputs itself and I can control them from OpenHab and also get updated values in OpenHab when I control it from the buttons to IHC.
My wireless dimmers, I have to create myself because the binding does not find them itself. If I use PaperUI, I can only make them work by creating them as “rollershutter”. If I link them to my items, I can also control the dimmers from OpenHab vi basicUI and PaperUi, but I do not get updated status in OpenHab if I control them from the IHC buttons.
Is there anyone who can explain me what’s wrong? If I look in the log, nothing happens when I dim or turn on / off via the IHC buttons.
.items file:
Switch Kitchen_Pendel “Køkkenbord” (Kitchen, gLight) {channel=“ihc:controller:Kitchen_Pendel”}
Switch Kitchen_Sokkel “Køkkensokkel” (Kitchen, gLight) {channel=""}
Dimmer Kitchen_Spots “Spots Køkken” (Kitchen, gBlind) {channel=“ihc:controller:Kitchen_Spots”}
.things file:
ihc:controller [ ip=“192.168.1.80”, username=“admin”, password=“xxxxxx”, timeout=5000, loadProjectFile=true, createChannelsAutomatically=false ] {
Channels:
Type switch-channel : Kitchen_Pendel “Køkken Pendler” [ resourceId=ihc:controller:27a89128:530779 ]
Type number-channel : Kitchen_Spots “Spots Køkken” [ resourceId=ihc:controller:27a89128:29459037 ]
I have both tried to configure the dimmer as number-channel and as dimmer-channel.
I simply do not know what I’m doing wrong or missing?
Latest test version should support automatic channel creation for wireless dimmers (https://openhab.jfrog.io/openhab/libs-pullrequest-local/org/openhab/binding/org.openhab.binding.ihc/2.4.0-SNAPSHOT/). Dimmer channels supports only direct level adjustment (0-100) so increase and decrease commands are not directly supported (you need to add rule to handle that).
Your configuration is not correct either:
- Thing doesn’t have a name (in my example below, thing name is controller1)
- Channel resourceId parameter should be resource Id from IHC project (530779)
ihc:controller:controller1 [ ip=“192.168.1.80”, username=“admin”, password=“xxxxxx”, timeout=5000, loadProjectFile=true, createChannelsAutomatically=false ] {
Channels:
Type switch-channel : Kitchen_Pendel “Køkken Pendler” [ resourceId=530779 ]
then your items should be linked to correct channel (ihc:controller:controller1:Kitchen_Pendel)
Switch Kitchen_Pendel “Køkkenbord” (Kitchen, gLight) {channel=“ihc:controller:controller1:Kitchen_Pendel”}
I had swapped around what was .items and .things file. I have corrected them so they are similar to your example, but it still does not work.
All I get on my wireless devices automatically is signal strength and low battery?
If you want to add a wireless dimmer to PaperUI, what should you do? I’ve only had luck with “RollerShutter” now. However, I do not get any updated values in OpenHab if I change the level in the IHC installation.
I tried reinstalling addon, and now it works. Thank you
Pauli, is it posible to make new temperature setpoint in the openhab binding, at get the controller to update these in the heating fb? Currently i can just figure out, how to read the current room temp, but it could be nice if i cold make the room setpoint from openhab app
Yes, you just need to select correct resource id from you IHC project.
I´m still on the old binding, unfortunatly. But this is how my item for setpoint looks like:
Number stort_bad_Tempsetpunkt "Stort Bad Temperature setpunkt [%.1f °C]" <temperature> (g_Stortbad_TSTAT) [ "TargetTemperature" ] {ihc="7989780"}
The source ID is the setpoint from the heating fb in IHC controller (Visual).
In my sitemap I´ve got this:
Setpoint item=stort_bad_Tempsetpunkt minValue=18 maxValue=25 step=0.5 label="Juster varmen"
You could also use this in sitemaps:
Selection item=stort_bad_Tempsetpunkt mappings=[21.0="21.0", 21.5="21.5", 22.0="22.0", 22.5="22.5", 23.0="23.0", 23.5="23.5", 24.0="24.0"]
Its a matter of taste I guess.
