Hi, had an IHC binding working nice in 2.2
When 2.3 was released it just stoped, and I have not been able to get i back on track since then
seems to have something with the *.sitemap to do… if I use the HABPanel it works, but not the Basic or Classic, thereby the IOS app, and Google assistant fails also.
logs generated loos like this when triggering the UI
2018-06-01 23:09:14.994 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SOFTLIGHT' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:09:14.997 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
So it just stop working with 2.3, config files did not change
I have re-installed the whole, still broken
it is a Rpi B+
removed the ihc from console, and readded it, scrolled the forum for few days and tried several actions but now I running out of ideas.
kamilu.sitemap
sitemap kamilu label="Kamilu" {
Frame label="Vardagsrum" {
Switch item=VRUM_FONSTER label="vardagsrum fonster" icon="light"
Switch item=VRUM_TAK label="vardagsrum tak" icon="light"
Frame label="Koket"{
Switch item=KITCHENLAMP label="Kokslampor" icon="light"
Frame label="Kontor"{
Switch item=R2_TAK label="Kontor Tak" icon="light"
Frame label="Kallare"{
Switch item=BASEMENT label="Källare lyse" icon="light"
Frame label="Luddesrum"{
Switch item=LUDDE_TAK label="Luddes taklampa" icon="light"
Frame label="Scenario"{
Switch item=SOFTLIGHT label="softlight" icon="light"
ihc.items
//Production Code
Switch Lampa_fonster_gata_1 "Lampa Fönster Gata 1" <switch> (SOFTLIGHT,VRUM_FONSTER,IHC,Livingroom,Lights) [ "Lighting" ] { ihc="0x7e75b" }
Switch Lampa_fonster_gata_2 "Lampa Fönster Gata 2" <switch> (VRUM_FONSTER,IHC,Livingroom,Lights) [ "Lighting" ] { ihc="0x7e45b" }
Switch Lampa_fonster_gata_3 "Lampa Fönster Gata 3" <switch> (SOFTLIGHT,VRUM_FONSTER,IHC,Livingroom,Lights) [ "Lighting" ] { ihc="0x7ed5b" }
Switch Lampa_fonster_gata_4 "Lampa Fönster Gata 4" <switch> (SOFTLIGHT,VRUM_FONSTER,IHC,Livingroom,Lights) [ "Lighting" ] { ihc="0x7ea5b" }
Switch Lampa_tak_vrum_whilke "Lampa Tak Whilke" <switch> (VRUM_TAK,IHC,Livingroom,Lights) [ "Lighting"] { ihc="0x25ce5b" }
Switch Lampa_tak_r2 "Lampa Tak Kontor" <switch> (R2_TAK,Office,Lights) [ "Lighting"] {ihc="0x25e05b"}
Switch Lampa_ludde_tak_under_loft "Lampa Ludde Tak soffa" <switch> (LUDDE_TAK) [ "Lighting" ] { ihc="0x15885" }
Switch Lampa_ludde_tak "Lampa Ludde Tak" <switch> (LUDDE_TAK) [ "Lighting" ] { ihc="0x15825b" }
Switch Basement_light "Lampa Källare" <switch> (BASEMENT) ["Lighting"] { ihc="0x13a05b"}
//Kitchen
Switch KitchenOvan3 "Kök Lampa Diskbänk" <switch> (KITCHENLAMP,IHC) [ "Lighting" ] { ihc="0x11415b" }
Switch KitchenDiskbankHoger_K_4 "Kök uttag Höger" <switch> (KITCHENPOWER,IHC) [ "Lighting" ] { ihc="0x11445b" }
Switch KitchenBjalken_K_5 "Kök uttag Bjälken" <switch> (KITCHENPOWER,IHC) [ "Lighting" ] { ihc="0x11475b" }
Switch KitchenTakOvanforSpisEjVidFlakt_K_6 "Kök tak" <switch> (KITCHENPOWERIHC) [ "Lighting" ] { ihc="0x114a5b" }
Switch KitchenTakOvanforKoksfonster_K_7 "Kök Tak ovan köksfönster"<switch> (KITCHENPOWERIHC) [ "Lighting" ] { ihc="0x114d5b" }
Switch KitchenOvanmat "Kök Lampa matplats" <switch> (SOFTLIGHT,KITCHENLAMP,IHC) [ "Lighting" ] { ihc="0x16e25b" }
Switch KitchenFlakt "Kök Fläkten" <switch> (KITCHENFAN,IHC) [ "Lighting" ] { ihc="0x21ff5b" }
Switch KitchenMatrumGolv "Kök Golvet tröskel" <switch> (KITCHENPOWER,IHC) [ "Lighting" ] { ihc="0x25d95b" }
Switch KitchenBakomKylKoksskap "Kök bakom kyl" <switch> (KITCHENPOWER,IHC) [ "Lighting" ] { ihc="0x267e5b" }
2018-06-01 23:29:46.320 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'kamilu.sitemap'
2018-06-01 23:29:47.419 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'kamilu.sitemap'
2018-06-01 23:30:02.471 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'VRUM_FONSTER' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.474 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'VRUM_FONSTER' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.477 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.480 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'VRUM_TAK' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.482 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'VRUM_TAK' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.485 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.488 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'KITCHENLAMP' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.490 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'KITCHENLAMP' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.492 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.495 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'R2_TAK' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.498 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'R2_TAK' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.500 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.503 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'BASEMENT' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.505 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'BASEMENT' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.507 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.509 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'LUDDE_TAK' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.512 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'LUDDE_TAK' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.514 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.516 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SOFTLIGHT' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.519 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'SOFTLIGHT' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-06-01 23:30:02.522 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
/m
