Hi there,
Trying to setup the IHC binding but can’t really seem to find the resource ids? Can anyone direct me in the right direction? Which file and where to find specifically?
Thank you very much
Cheers,
Peter
Hi there,
Thank you very much
Cheers,
Peter
When i look in the .BAK project file i can find “airlink id’s”…would that be the one?
<product_airlink id="_0x65254" product_identifier="_0x4304" device_type="_0x808" name="Lampeudtag dimmer" serialnumber="_0x640813390435" locked="yes" position="Spots" icon="_0x86">
<airlink_dimmer_increase id="_0x6535f" name="Tænd / regulér op" address_channel="_0x1"/>
<airlink_dimmer_decrease id="_0x65460" name="Sluk / regulér ned" address_channel="_0x1"/>
<airlink_dimming id="_0x6555d" name="Lys niveau" address_channel="_0x1"/>
<light_indication id="_0x6561d" name="Lys indikering" note="'On' når lysdæmperen er tændt"/>
<scenes id="_0x65749" name="Scenarier/regulering" scene_resource="_0x6555d">
<scene_dimmer id="_0x76c4c" name="Scenarie link" dimming_value="100" ramptime_ms="1000" link="_0x76d4b"/>
<scene_dimmer id="_0x8ff4c" name="Scenarie link" ramptime_ms="1000" link="_0x9004b"/>
<scene_dimmer id="_0x9684c" name="Scenarie link" dimming_value="50" ramptime_ms="1000" link="_0x9694b"/>
<scene_dimmer id="_0x9e34c" name="Scenarie link" dimming_value="85" ramptime_ms="1000" link="_0x9e44b"/>
<scene_dimmer id="_0xbce4c" name="Scenarie link" dimming_value="60" ramptime_ms="1000" link="_0xbcf4b"/>
<scene_dimmer id="_0xc454c" name="Scenarie link" ramptime_ms="1000" link="_0xc464b"/>
</scenes>
<dimmer_settings id="_0x6586e">
<dimmer_setting_minimum_value id="_0x65971" value="22" maximum="100"/>
<dimmer_setting_maximum_value id="_0x65a72" value="100" maximum="100"/>
<dimmer_setting_fade_rate_up id="_0x65b6f" value="700" minimum="200" maximum="60000"/>
<dimmer_setting_fade_rate_down id="_0x65c70" value="700" minimum="200" maximum="60000"/>
<dimmer_setting_dimming_rate id="_0x65d73" value="5000" minimum="2000" maximum="10000"/>
<dimmer_setting_load_mode id="_0x65e74"/>
</dimmer_settings>
</product_airlink>
<product_airlink id="_0x65f54" product_identifier="_0x4201" device_type="_0x804" name="Stikkontakt" serialnumber="_0x640413380100" locked="yes" enduser_report="yes" position="Bag sofa (lampe)" icon="_0x88" note="Trykkene styrer stikkontakten direkte">
<airlink_relay id="_0x6605e" name="Udgang" address_channel="_0x1" backup="yes">
<link_to_resource id="_0x6982c" name="Følg Link" icon="_0x4a" link="_0x6972d"/>
</airlink_relay>
<scenes id="_0x66149" name="Scenarier" scene_resource="_0x6605e">
<scene_relay id="_0x9014d" name="Scenarie link" link="_0x9024b"/>
<scene_relay id="_0x96a4d" name="Scenarie link" relay_value="on" link="_0x96b4b"/>
<scene_relay id="_0x9e14d" name="Scenarie link" relay_value="on" link="_0x9e24b"/>
<scene_relay id="_0xbd04d" name="Scenarie link" relay_value="on" link="_0xbd14b"/>
<scene_relay id="_0xc474d" name="Scenarie link" link="_0xc484b"/>
<scene_relay id="_0xcb84d" name="Scenarie link" relay_value="on" link="_0xcb94b"/>
<scene_relay id="_0x10bc4d" name="Scenarie link" relay_value="on" link="_0x10bd4b"/>
<scene_relay id="_0x10be4d" name="Scenarie link" link="_0x10bf4b"/
Just hold down the CRTL key in the visual software and hover the item you need id for
Ah so simple… thanks!
