Hi Holger,
thanks a lot!
But unfortunately after putting the .jar in the addons folder and a restart, the binding couldn’t be installed (running openHAB 2.2.0 Build #1043):
[ERROR] [rg.eclipse.smarthome.binding.tradfri] - FrameworkEvent ERROR - org.eclipse.smarthome.binding.tradfri
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.binding.tradfri [213]
Unresolved requirement: Import-Package: org.eclipse.californium.core
at org.eclipse.osgi.container.Module.start(Module.java:444) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1599) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
Great, thanks a lot!
After a quick test it seems to run overall fine. But when I change the color in the IKEA Trådfri iOS App to the darkest blue, I get the following error:
2017-09-26 19:17:37.493 [ERROR] [alifornium.core.network.CoapEndpoint] - Exception in protocol stage thread: Value must be between 0 and 100
java.lang.IllegalArgumentException: Value must be between 0 and 100
at org.eclipse.smarthome.core.library.types.PercentType.validateValue(PercentType.java:50) [98:org.eclipse.smarthome.core:0.9.0.201709260841]
at org.eclipse.smarthome.core.library.types.PercentType.<init>(PercentType.java:35) [98:org.eclipse.smarthome.core:0.9.0.201709260841]
at org.eclipse.smarthome.core.library.types.HSBType.fromRGB(HSBType.java:114) [98:org.eclipse.smarthome.core:0.9.0.201709260841]
at org.eclipse.smarthome.binding.tradfri.internal.TradfriColor.constructHsbTypeFromRgbWithBrightnessPercent(TradfriColor.java:247) [186:org.eclipse.smarthome.binding.tradfri:0.9.0.201709260841]
at org.eclipse.smarthome.binding.tradfri.internal.TradfriColor.fromCie(TradfriColor.java:133) [186:org.eclipse.smarthome.binding.tradfri:0.9.0.201709260841]
at org.eclipse.smarthome.binding.tradfri.handler.TradfriLightHandler$LightData.getColor(TradfriLightHandler.java:423) [186:org.eclipse.smarthome.binding.tradfri:0.9.0.201709260841]
at org.eclipse.smarthome.binding.tradfri.handler.TradfriLightHandler.onUpdate(TradfriLightHandler.java:140) [186:org.eclipse.smarthome.binding.tradfri:0.9.0.201709260841]
at org.eclipse.smarthome.binding.tradfri.internal.TradfriCoapHandler.onLoad(TradfriCoapHandler.java:60) [186:org.eclipse.smarthome.binding.tradfri:0.9.0.201709260841]
at org.eclipse.californium.core.CoapClient$ObserveMessageObserverImpl.deliver(CoapClient.java:1067) [175:californium-osgi:1.0.6]
at org.eclipse.californium.core.CoapClient$MessageObserverImpl.succeeded(CoapClient.java:995) [175:californium-osgi:1.0.6]
at org.eclipse.californium.core.CoapClient$MessageObserverImpl.onResponse(CoapClient.java:974) [175:californium-osgi:1.0.6]
at org.eclipse.californium.core.coap.Request.setResponse(Request.java:509) [175:californium-osgi:1.0.6]
at org.eclipse.californium.core.network.EndpointManager$ClientMessageDeliverer.deliverResponse(EndpointManager.java:267) [175:californium-osgi:1.0.6]
at org.eclipse.californium.core.network.stack.CoapStack$StackTopAdapter.receiveResponse(CoapStack.java:193) [175:californium-osgi:1.0.6]
at org.eclipse.californium.core.network.stack.AbstractLayer.receiveResponse(AbstractLayer.java:98) [175:californium-osgi:1.0.6]
at org.eclipse.californium.core.network.stack.ObserveLayer.receiveResponse(ObserveLayer.java:137) [175:californium-osgi:1.0.6]
at org.eclipse.californium.core.network.stack.BlockwiseLayer.receiveResponse(BlockwiseLayer.java:321) [175:californium-osgi:1.0.6]
at org.eclipse.californium.core.network.stack.ReliabilityLayer.receiveResponse(ReliabilityLayer.java:269) [175:californium-osgi:1.0.6]
at org.eclipse.californium.core.network.stack.CoapStack.receiveResponse(CoapStack.java:135) [175:californium-osgi:1.0.6]
at org.eclipse.californium.core.network.CoapEndpoint$InboxImpl.receiveMessage(CoapEndpoint.java:656) [175:californium-osgi:1.0.6]
at org.eclipse.californium.core.network.CoapEndpoint$InboxImpl.access$700(CoapEndpoint.java:562) [175:californium-osgi:1.0.6]
at org.eclipse.californium.core.network.CoapEndpoint$InboxImpl$1.run(CoapEndpoint.java:574) [175:californium-osgi:1.0.6]
at org.eclipse.californium.core.network.CoapEndpoint$5.run(CoapEndpoint.java:721) [175:californium-osgi:1.0.6]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
I’m trying to start up with this binding - however i don’t have a remote to the Gateway - will there be any other solution for pairing the bulbs with the gateway other than i need to buy a remote only for the pairing? The binding can’t do something like that?
I noticed @OMR mentioning a buzzing noise on the 30x90 FLOALT, and the 30x30 being dead silent. I experience the exact same thing here. And it was so noisy i exchanged it at the Ikea warehouse for a new one, but its the same noise on this one. Experiences? My house is quiet when the kids are outdoors
Thanks for the group for adding the trådfri binding! It’s a great to see how neatly it works.
One question about the groups, have they been introduced only in 2.2 or should they work also in 2.1?
I have the 2.1 release version of the binding running, if 2.2 is required, is the Jar somewhere available, or do I need to drag myself to my dev system and build one? Additionally, how can I figure out the group id? Or would a newer version of the binding discover those automatically as well?
Thank you for the binding, it has been working very well.
I have noticed an issue, if I restart OpenHab, the TradFri gateway, and the router at the same time (I’ve been having power outages due to storm). The binding will not correctly connect.
What appears to happen is:
The gateway restarts and uses a self-assigned IP address because the router is not yet booted.
Openhab starts, the binding discovers the gateway, and stores it’s IP.
The router starts, and the gateway receives the correct IP (via DHCP).
The binding doesn’t detect the change.
Restarting Openhab corrects the problem, but it would be nice to work correctly from a cold start.
I bought the bulb in a german IKEA store. At that time they weren’t listed online. So maybe it’s only a matter of time until they are available at the Canadian IKEA site, maybe they are also already available at the local IKEA stores.
