Ikea Tradfri LED1649C5 e14 dimming bulb via zigbee2mqtt
Tags: #<Tag:0x00007f616cc0e160> #<Tag:0x00007f616cc0dfa8>
We have an Ikea Tradfri e14 400lm dimmable bulb.
Here is how I integrated into openHAB, via zigbee2mqtt and Mosquitto .
Prerequisites
  • Ensure the openHAB MQTT binding is installed (V2, not V1)
  • My Mosquitto MQTT broker is setup as per default.
  • Pair the device with zigbee2mqtt as described here .
    • Ensure that you are able to pair devices by setting permit_join to true in configuration.yaml (usually in /opt/zigbee2mqtt/data)
  • Once paired, adjust the zigbee2mqtt configuration.yaml (usually in /opt/zigbee2mqtt/data) to:
Here is my configuration.yaml - your device ID is likely to be different. I have given my device the friendly name swPorchLight :
homeassistant: false
permit_join: true
mqtt:
  base_topic: zigbee2mqtt
  server: 'mqtt://localhost'
serial:
  port: /dev/ttyACM0
  disable_led: false
advanced:
  log_level: error
  availability_timeout: 5
devices:
  '0x086bd7fffe210efc':
    friendly_name: swPorchLight
experimental:
  output: attribute
openHAB
bridge.things
I have a separate file which just contains the bridge Thing to my Mosquitto MQTT broker:
Bridge mqtt:broker:MosquittoMqttBroker "Mosquitto MQTT Broker" [
	host="192.168.1.92",
	secure=false,
	port=1883,
	clientID="OpenHAB2"
zigbee.things
//Porch light
Thing mqtt:topic:swPorchLight "Porch Light" (mqtt:broker:MosquittoMqttBroker) {
	Channels:
	    Type switch:switch "Power Switch" [
			stateTopic="zigbee2mqtt/swPorchLight/state",
			commandTopic="zigbee2mqtt/swPorchLight/set",
			on="ON",
			off="OFF"
	    Type dimmer:dimmer "Dimmer" [
			stateTopic="zigbee2mqtt/swPorchLight/brightness",
			commandTopic="zigbee2mqtt/swPorchLight/set/brightness",
			min=0,
			max=255,
			step=1
	    Type switch:reachable "Reachable" [
			stateTopic="zigbee2mqtt/swPorchLight/availability",
			on="online",
			off="offline"
zigbee.items
Switch sPorchLight "Porch Light" { channel="mqtt:topic:swPorchLight:switch" }
Dimmer dPorchLight "Porch Light" {channel="mqtt:topic:swPorchLight:dimmer"}
Switch sPorchLightReachable "Porch Light" { channel="mqtt:topic:swPorchLight:reachable"}
sitemap
Text item=sPorchLightReachable label="Porch light [MAP(switch2online.map):%s]" icon="light" valuecolor=["ON"="green", "OFF"="red", "NULL"="red", "-"="red"]
Switch item=sPorchLight label="Porch" icon="light"
Slider item=dPorchLight label="Brightness [%d %%]" sendFrequency=500
The switch2online.map file contains the below, saved into the transform folder:
OFF=OFFLINE
ON=ONLINE
NULL=UNDEFINED
