[21:23:34] openhabian@openhab:~$ sudo ls -al var/lib/openhab2/cache/
ls: cannot access 'var/lib/openhab2/cache/': No such file or directory
[21:23:49] openhabian@openhab:~$ sudo ls -al var/lib/openhab2/tmp/
ls: cannot access 'var/lib/openhab2/tmp/': No such file or directory
[21:24:03] openhabian@openhab:~$
Use openhabian-config tool and select option to delay starting rules (option 44) for optimal startup then restart OH with sudo systemctl restart openhab2 if restart is not correct then just use stop and then same command with start.
var Timer BlinkingTimer = null
rule "Network Router OFF"
Item Router changed to OFF
logInfo("network", "Router is offline")
if(BlinkingTimer !== null){
BlinkingTimer.cancel()
if(BlinkingTimer === null){
BlinkingTimer = createTimer(now.plusMillis(500), [ |
if(GPIO_OKLed.state==ON){
logInfo("network", "LED OFF")
GPIO_OKLed.sendCommand(OFF)
BlinkingTimer.reschedule(now.plusMillis(150))
}else{
logInfo("network", "LED is "+ GPIO_OKLed.state.toString() +", and will set ON")
GPIO_OKLed.sendCommand(ON)
rule "Network Router ON"
Item Router changed to ON
logInfo("network", "Router is online")
log errors
2019-11-23 22:01:04.448 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Network Router OFF': An error occurred during the script execution: Cannot resolve proxy: network.rules#/1
2019-11-23 22:01:04.500 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2019-11-23T22:01:02.545+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@35b88
} ] threw an unhandled Exception:
java.lang.NullPointerException: cannot invoke method public abstract boolean org.eclipse.smarthome.model.script.actions.Timer.reschedule(org.joda.time.base.AbstractInstant) on null
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1071) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1061) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1047) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:992) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:772) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:220) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:464) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:244) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
at com.sun.proxy.$Proxy158.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
2019-11-23 22:01:04.780 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2019-11-23T22:01:02.545+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [107:org.eclipse.smarthome.core.scheduler:0.10.0.oh240]
Caused by: java.lang.NullPointerException: cannot invoke method public abstract boolean org.eclipse.smarthome.model.script.actions.Timer.reschedule(org.joda.time.base.AbstractInstant) on null
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
... 1 more
Why all the timers and why the first if statement? Itās canceling a timer that hasnāt even started.
What makes you think it stopped? Is there an error report we should see?
is good practice cos us mere mortals can see what it does at a glance
will do the exact same thing though.
Just in case, you do not have any Timer imports you may have seen suggested in old postings?
This is a bit alarming really -
2019-11-23 15:14:44.013 [INFO ] [lipse.smarthome.model.script.network] - Router is offline
2019-11-23 15:14:46.856 [INFO ] [lipse.smarthome.model.script.network] - LED is NULL, and will set ON
Nearly three seconds between those logInfo, when it should be a few mS. How stressed is this system? Are there many other timer jobs grabbing resource?
I note that there seems to be an MQTT broker initialising in the middle of all this, are we in the midst of a bootup?
Note this old post for same error -
You might expect an orphaned timer error after editing a rule file - but your timer should only take seconds to blow up.
Iām so frustrated, here is my latest errors
Iām trying to check the internet connection and blink the led according to the problem in the connection, first Iāll check if the router is online, if not blink the led fast, if online go to check the internet connection if offline blink the led slowly, if online turn the led on, but as you see iām still in the first step and errors stopped me
rules
BlinkingTimer = createTimer(now.plusSeconds(1), [ |
if(GPIO_OKLed.state == ON){
BlinkingTimer.reschedule(now.plusMillis(250))
}else{
2019-11-24 11:29:30.945 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Network Router OFF': An error occurred during the script execution: Cannot resolve proxy: network.rules#/1
2019-11-24 11:29:30.971 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2019-11-24T11:29:28.824+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@1069f1e
at com.sun.proxy.$Proxy153.apply(Unknown Source) ~[?:?]
2019-11-24 11:29:31.189 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2019-11-24T11:29:28.824+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
... 1 more
There is something weird about your BlinkingTimer variable; I donāt know what, duplicate declaration somewhere else? donāt know.
But it breaks your rule ā¦ ... Rule 'Network Router OFF': An error ... Cannot resolve proxy: network.rules#/1
Iām pretty convinced that comes from the cancel attempt
AND it breaks the timer block ... cannot invoke method ... .Timer.reschedule... on null
obviously from the reschedule attempt.
Have a think about that; the āOFFā rule breaks before it creates the timer, but the timer breaks as well?
Youāve hidden from us the logInfo output from the beginning of the rule, that would reveal multiple entries into the rule. So first, find out if your rule triggers multiple times.
Youāve taken the logInfos out of your timer code that would reveal what that is up to. Youāve made the flashing schedule more demanding. Itās not helping. I understand your frustration, weāre looking for an oddball race condition.
Do some basics -
Make sure you have no timer import in that file.
Make sure your global var Timer is at the top of the file, before any rules.
Sprinkle logInfos to see how far things get. Youāve never mentioned if the LED does anything.
Donāt forget that when you edit a rule file that has already spawned a timer that is still running, that timer will keep on running, but probably fail later because something in inaccessible, null.
Not a fix, a suggested diagnostic -
logInfo("network", "old timer " + BlinkingTimer.toString)
// it's always null if we get this far
logInfo("timer", "my handle is " + BlinkingTimer.toString)
}else{
BlinkingTimer.reschedule(now.plusMillis(1000))
Looking at OPās items, the rule is started with Item Router changed to OFF, but there is no Router listed in items file only GPIO_OKLed and GPIO_WULed. This would explain the rule breaking before the timer?
If there were no Item Router, it could never change, and the rule would never run at all.
In post one there is actually a Router Item, but weāve been a long way round since then.
My point about both rule and the timer it spawns breaking, is that there is more than one rule execution involved.
Iām convinced this is all about the circular reference inside the timer block to its own handle. That isnāt a problem, until you mess with that handle. Typically by reloading the rules file.
That brings a thought - at load time, you should see in openhab.log "xxx.rules loaded" - do you see a multiple message for this file?
